Home > Technical > THE webasto Thread
Page 12 of 16 <123 ... 111213 141516>
jst
nearly done then thats good.
to save the hassle with the pipe work and the sock remote send thos old shocks down to me and i will send some replacements up without an ext res then you wont need to worry about it.
considering the heat the shock gets too i wouldn't of thought it would be an issue if they did contact. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #212629 20th Feb 2013 1:57pm
mobilecentre
Here are some pictures of the 4 way heater valve
Post #247743 30th Jun 2013 11:26am
dgardel
Italy
This is my installation:
Installation without 4 ways valve
Installation with
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #247748 30th Jun 2013 12:04pm
I was not keen on installing in the gearbox tunnel because it's more exposed to the elements and more difficult to service, so after alot of research, I opted for a BMW X5 installation kit from Webasto Switzerland.
Tidy, up out of the way installation and easy access Thumbs Up
Post #249471 6th Jul 2013 6:47am
marek916
Hi,
This is my first post here.
I can connect to the Webasto Thermo Top Vevo (2011 ex LR Discovery part) with the W-Bus using an eBay USB OBD (beware pin 5 was not connected in my OBD adapter so had to use pin 4 (signal GND vs Vehicle GND).
In my "Control" menu of Webasto Thermo Test software v2.14 "on", "EMC measurement mode", "ventilating", "boost mode" and "circulating pump external control" are greyed out.
When I click one of the four non -greyed out options "Parking Heating", "Parking Heating (EOL)", "Supplemental Heating" or "Supplemental Heating (EOL)" I get the "NAK: access denied!".
Please see attached screenshots.
On the VW forums I have seen references to modifying a CANbus register with VAG-COM to enable the W-bus control. I have connected the CANbus lines to my OBD and installed VAG-COM but the Webasto does not show up on in the bus scan (I have tried an all address scan).
Has anyone else got experience in this area?
Thanks
Marek
Post #353076 22nd Aug 2014 9:51am
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
Hi Marek welcome to the forum.
It's worth having a read of this whole thread from Page 1 in particular tatra805's posts. I think the problem you have is that whilst a lot of the Webastos look identical there are a number of manufacturer specific versions (in terms of the electricals/pcb) and it can sometimes be difficult/impossible to make these work as standalone heaters. I'm not sure if this is the case with the Discovery version but I believe it was originally intended as a supplementary heater rather than a parking heater.
Post #353253 23rd Aug 2014 10:34am
cosmin
Romania
hey guys, so I have a webasto air top 2000 ST from a mercedes actros, is there any way I can make it run without CAN BUS and install it on any truck I want ?
Post #457585 23rd Sep 2015 8:11pm
If you have a degree in electronics I'd say go for it, otherwise bite the bullet and buy a new standard kit from Derrick at LRS
There are also lots on eBay but buy with care ... People offload all sorts of webasto and eberspacher units there
Post #457618 23rd Sep 2015 10:34pm
Martin
Site Admin
Anyone know if there is a replacement or alternative part number for the 12780A 4-port one-way valve?
It's disappeared from Webasto suppliers Confused  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #503410 11th Feb 2016 11:46am
dgardel
Italy
Post #503991 12th Feb 2016 6:13pm
Martin
Site Admin
Thanks Daniele Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #504038 12th Feb 2016 8:07pm
drinkdrinkdrop
Anyone controlling a thermo top and an airtop with a single controller? I'd also quite like the ability to remotely activate them separately but I'm struggling to see how this is possible with a t91
Post #567777 30th Sep 2016 10:18am
TJH1985
Hey All,
Would you mind sharing some pictures of your exhaust routing and exit?
Thanks,
Tom
Post #743531 2nd Dec 2018 12:18pm
dgardel
Italy
https://www.defender2.net/forum/post160364.html#160364 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #743536 2nd Dec 2018 12:41pm
Anyone fitting a webssto thermotop to a LHD defender, I have a mounting kit
Post #743635 2nd Dec 2018 11:16pm
