Home > Technical > THE webasto Thread
Page 11 of 16 <123 ... 101112 ... 141516>
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
bpman wrote:
could be the fuel filter in the pump is blocked... you've been using non-BP fuel ?
Wouldn't dare Wink
Booked in at D44 next week to sort out. Got to get fixed ASAP for Norway, only 19 days to go and so much to do 2007 TD5 90 Hard Top
Post #198557 3rd Jan 2013 8:38am
jst
did you check the filter? where is the pickup? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #198843 4th Jan 2013 10:13am
Landlord
Afaik there is no fuel filter for the FBH as it comes straight off the tank. The FBH has its own fuel pick up. I'm planning to have another look this weekend to see if I can sort it out. 2007 TD5 90 Hard Top
Post #199029 4th Jan 2013 9:38pm
Nige
there is a tiny fuel filter on the end of the pump
see the thermotop service manual section 8
"inspect fuel lines and fuel filter for leakage."
Post #199052 4th Jan 2013 10:08pm
Landlord
It must be tiny, had a good look this week and couldn't find it. Will check again tomorrow and try to bleed the fuel system. 2007 TD5 90 Hard Top
Post #199074 4th Jan 2013 10:44pm
JWL
Crack open the inlet side of the fuel pump and there is a gauze filter in the pipe as it comes out of the pump.
Post #199084 4th Jan 2013 11:18pm
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
mobilecentre wrote:
We cannot compete with some of the pricing on Thermo top C's you guys find but do have an alternative for Puma mounting which is under the n/s wing on RHD cars using our own custom bracket Thumbs Up
Tim, you posted this a while back. I see from your website that you offer a complete fitting kit, including Webasto itself.
Would you consider selling just the bracket alone for those of us cobbling something together?
Post #204333 22nd Jan 2013 2:50pm
jst
i put mine there using the std bracket that comes in the kit working off a fixing on the top wing fold down section. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #204342 22nd Jan 2013 3:10pm
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
Webasto air top 2000
Hello,
I am trying to install a Air top 2000 at the place of the cubybox.
if I think it will be ok for that after some modifications because the exhaust pipe is near a tube with diesel ...
my question is about the connection for the diesel.
I am afraid to cut the tube before the filter because :
- the tube looks vey big and afraid to make a mistake with bad results for the engine
- not sure there will be no air in the alimentation of the diesel pump of the engine
the best way could be a connection on the tank but it will need to take it of
an other way is a separate little tank ...
if somebody have made it on a defender with the 2.2 engine 2012, thanks to help me
regards,
Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #212069 18th Feb 2013 10:45am
jst
i considered all the options and in the end decided that dropping the tank and fitting the proper pick up was the way to do it, so went that route.
a smaller diesel tank would just be a pain.
if you are plumbed into the engine supply and have a failure it could affect engine running.
you can get a pickup that you fit in part of the filler neck with an arm that goes down to the tank, that would work. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #212138 18th Feb 2013 3:08pm
Phil VM2.5
hello,
thanks for the answer
Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and
1987 BMW GS80
Post #212331 19th Feb 2013 11:07am
Les Brock
Hi Chaps
Can anyone give me some idea of the external surface temperature the Thremotop gets up to ?
Might end up with a pipe close to/if not touching the metal section Big Cry
Thanks
Regards
Les
Post #212381 19th Feb 2013 4:12pm
Phoenix90
United Kingdom 2007 Defender 110 Puma 2.4 USW Stornoway Grey
Les Brock wrote:
Hi Chaps
Thanks
Regards
Les
So long as coolant is flowing through it then not much hotter than the coolant itself.
Post #212451 19th Feb 2013 8:20pm
jst
it wont be an issue Les.
does this mean you may finish the build? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #212473 19th Feb 2013 9:05pm
Les Brock
Thanks for the reply chaps Bow down
The pipe in question is for the shock remote reservoir I have sleeved it, but was trying to make sure as I dont really want to be damaging it if I can help it Wink
James,
Yes still progressing albeit very slowly, almost ready to get the fire extinguisher ready, to fire up (no pun intended Rolling with laughter ) the electrics for the first time Whistle
Need to speak to Jamie to borrow his nanocom and hopefully a huge hurdle out of the way
doors/sides/windscreen/roof/tub floor to finish and done Thumbs Up
Regards
Les
Post #212596 20th Feb 2013 10:56am
