![]() | Home > Technical > THE webasto Thread |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8491
did you check the filter? where is the pickup? Cheers
| Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582
Afaik there is no fuel filter for the FBH as it comes straight off the tank. The FBH has its own fuel pick up. I'm planning to have another look this weekend to see if I can sort it out. 2007 TD5 90 Hard Top
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
Nige
there is a tiny fuel filter on the end of the pump see the thermotop service manual section 8 "inspect fuel lines and fuel filter for leakage." |
It must be tiny, had a good look this week and couldn't find it. Will check again tomorrow and try to bleed the fuel system. 2007 TD5 90 Hard Top
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443
Crack open the inlet side of the fuel pump and there is a gauze filter in the pipe as it comes out of the pump.
| Inigo Member Since: 13 Nov 2011 Location: Kent Posts: 627
Tim, you posted this a while back. I see from your website that you offer a complete fitting kit, including Webasto itself. Would you consider selling just the bracket alone for those of us cobbling something together? |
i put mine there using the std bracket that comes in the kit working off a fixing on the top wing fold down section. Cheers
| Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196
Hello,
I am trying to install a Air top 2000 at the place of the cubybox. if I think it will be ok for that after some modifications because the exhaust pipe is near a tube with diesel ... my question is about the connection for the diesel. I am afraid to cut the tube before the filter because : - the tube looks vey big and afraid to make a mistake with bad results for the engine - not sure there will be no air in the alimentation of the diesel pump of the engine the best way could be a connection on the tank but it will need to take it of an other way is a separate little tank ... if somebody have made it on a defender with the 2.2 engine 2012, thanks to help me regards, Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
i considered all the options and in the end decided that dropping the tank and fitting the proper pick up was the way to do it, so went that route.
a smaller diesel tank would just be a pain. if you are plumbed into the engine supply and have a failure it could affect engine running. you can get a pickup that you fit in part of the filler neck with an arm that goes down to the tank, that would work. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
hello,
thanks for the answer Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
| Les Brock Member Since: 20 Mar 2012 Location: Stroud, Glos Posts: 188
Hi Chaps
Can anyone give me some idea of the external surface temperature the Thremotop gets up to ? Might end up with a pipe close to/if not touching the metal section Thanks Regards Les |
| Phoenix90 Member Since: 04 Mar 2012 Location: Cornwall Posts: 377
So long as coolant is flowing through it then not much hotter than the coolant itself. |
it wont be an issue Les.
does this mean you may finish the build? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Thanks for the reply chaps
The pipe in question is for the shock remote reservoir I have sleeved it, but was trying to make sure as I dont really want to be damaging it if I can help it James, Yes still progressing albeit very slowly, almost ready to get the fire extinguisher ready, to fire up (no pun intended Need to speak to Jamie to borrow his nanocom and hopefully a huge hurdle out of the way doors/sides/windscreen/roof/tub floor to finish and done Regards Les Last edited by Les Brock on 20th Feb 2013 1:13pm. Edited 1 time in total |
| All times are GMT |
