![]() | Home > Maintenance & Modifications > Corrosion Prevention Guide! |
| Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026
Practical and real life feedback from forum members has contributed greatly to this thread from off-roading hacks to concours vehicles and despite the blanket marketing of new fad products falsely stating ease of use and stopping rust, most have the common sense to realise there are no short cuts to rust prevention (you have to be methodical, prep is everything, do one section at a time and yes it will be messy and dangerous to your lungs to use) and coupled with the use of tried and tested recommended products your vehicle can be kept in very good condition avoiding corrosion which can cost thousands to rectify or drop the value of your vehicle by 3-5K in some cases. It's better to prevent corrosion than try and rectify it, once rot has set in, in some cases it cannot be easily rectified. Forget your snorkels and wheels for the moment, get some rust prevention on it first, this guide will hopefully help you |
| Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553
Thanks for coming back Zagato, I do appreciate your time. Unfortunately I had coated the chassis with Lanoguard before reading this reply. I am now worried that I have done the wrong thing. You did mention references to social media reviews of Lanoguard where problems were mentioned, but unfortunately I can't find them - would you have a link as I would like to read them? Thanks for your help. Mick |
Don,t worry Mossberg, you won,t have harmed anything it's just your efforts could have been better utilised BUT as they say constantly on Facebook posts (where real world negative posts come up, temporarily that is!!) all you do is simply squirt it on... so hopefully it wasn't a major job for you
Once again you have to treat rust. Simply coating it with a barrier will obviously not stop it. Grind back rust then; Treat with either ACF-50 or an acid rust converter like Dinitrol RC900 (DO NOT BREATH EITHER IN). Then Dinitrol 1000 Then Dinitrol 4941 Dinitrol Stone chip where required Dinitrol 1000 for your cavities If you have a very good condition chassis... you are blessed |
| dainger Member Since: 08 Feb 2022 Location: Harpenden Posts: 69
So I had this sand blasted and re-sprayed 9 months ago and already the corrosion is coming back through.
Is this just to be expected? Any recommendations on how to fix / stop this getting worst? Thanks. Click image to enlarge Click image to enlarge |
| Crofter Member Since: 19 Feb 2015 Location: Peterhead Posts: 169
Guys I have found this thread useful, so now I want to put it into practice.
I have a 2009 110 defender I have twice had it under sealed in it life with wax oil. Basically I cleaned up the chassis and a local garage would do the spraying. The guy who did the spraying is not longer with us, so I need to do it myself. Would I be better sticking with Wax Oil or is the other stuff better? I see they are available on EBay. Thanks |
Sadly you will not be able to stop this corrosion which happens on the vast majority of later Defenders especially around the 14 plate age which seem to be particularly bad. It is a "metal"/"alloy" mix if you know what I mean in simple termsm, where corrosion would have started before the frame was even put on the vehicle. You can take the corrosion right back but it will come back through in no time. Have a look at other Defenders, most have already been resprayed and it's coming back through! ACF-50 will slow it down slightly but I say to most of my clients if you can source a NOS good one, hang onto it, it will be gold dust and hopefully somebody will produce better quality frames in time. |
Glad you have found the thread useful. You will have already read your answer... that the consensus is the other stuff is better |
That’s great all be it bad to hear. Sorry for my ignorance, what does “NOS”? Stand for? Thanks. |
| kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074
New old stock
Thank you. 👌
| Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 697
If I wanted to put ACF50 under Dinitrol how long does it need to dry?
If applying it thickly, leave it a day minimum.
| Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3786
What do you mean by this? Are you applying ACF50 and then dinitrol over the top? If so, what is the reason? I am doing some dinitrol applications in the next few weeks and wondered if I should be doing the same! |
| All times are GMT |
