Home > Maintenance & Modifications > Corrosion Prevention Guide!
Page 88 of 89 <123 ... 878889>
keith
C90. Thank you for your support and advice once again.
I did infact replace a CV only couple of years ago but cannot remember which side, is there a way to tell? I’ll be cleaning out and lubricating tomorrow but cannot find Ashcrofts HD flanges anywhere in stock. Any other reputable suppliers?
Keith.
Post #1067113 5th May 2025 9:36pm
keith
custom90 wrote:
Keith - If I was you I would change those DM’s ASAP, clean up and thoroughly grease.
Otherwise, if the splines get severely worn then you’ll need new CV’s etc, swivel grease won’t hurt as well anyway.
If you replace the DM’s with something like Ashcroft HD upfront, that’ll keep those in good stead.
Back on subject, yes, I agree with Zag.
Dinitrol, I’ve found to be excellent, and still is on mine.
I went for brown internal wax and black external, I use the black external often when replacing or changing things over, it just stops the elements getting at where it shouldn’t.
For the basics like black paint in some places, like bumpers etc just a little black paint and artists paint brushes work, especially if there is Powder Coat being a pain in visual areas.
For everything hidden though, black Dinitrol is ace, brown in cavities, ACF 50 on this that are visible.
Only thing is ACF 50 stinks, also keep it off of rubbers it doesn’t play nice with those, but is good for painted visible internal seatbox seams as an example.
As mentioned, I’d keep it away from plastics or rubbers though, it will perish those.
Painted surfaces or metals are fine though.
This is just my views and opinion, Zag is the expert here.
Funny I see this thread now, this week I’ve been cleaning out the dirt traps mentioned above!
Thumbs Up
C90, Hi
Iv just been told that actually HD flanges won’t fit on my Puma with standard Boost alloy wheels. I didn’t know this so maybe I’m stuck with basic flanges.
Post #1067130 6th May 2025 10:36am
They do fit but you’ll need to change the fixings for hex cap head (allen) 12.9 grade and spring washers.
This is because the standard DM bolts can clash with the boosts, with the hex cap fixings it’s not an issue.
It was Blackwolf on here who I believe pioneered this, I followed suit as well and had no issues at all since.
The Ashcroft HD DM’s have a larger surface area too, so in my opinion reduces fretting of the splines kept well greased.
Of course you can use 1 piece on the rear, I may do this next time but currently have Ashcroft 2 piece and have been happy. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1067185 6th May 2025 10:52pm
You can buy from Ashcroft direct here:
https://ashcroft-transmissions.co.uk/produ...e-flanges/
Regards fixings, somewhere like Kay’s Fixings on eBay is ideal, just be sure the bolts are the correct hi tensile grade, and length.
I cannot remember the exact length off the top of my head now.
I went for black ones with stainless string washers, but it doesn’t matter much the colour..
Hope that might be helpful, they certainly do fit boosts as this is what I have, coupled with 255/85 tyres. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1067187 6th May 2025 10:57pm
keith
C90. These ones pal. Iv had em in the box for yrs. now I just need an HD supplier. There’s more than Ashcroft. I need em now.
Post #1067188 6th May 2025 11:00pm
That’s the type indeed. Thumbs Up
I think Terrafirma do something similar. (DM’s). ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1067189 6th May 2025 11:05pm
keith
Recommended from previous posts I have this for my back box. However there is another more expensive tin from the same manufacturer. Same black but glass reinforced. Any better than this one?
Post #1067190 6th May 2025 11:13pm
keith
There are 3 part Numbers. Is it 859 or 5806m or 5806? Thank you.
Now Iv read the description it’s the 859 for the tdci. 🙄
Post #1067191 6th May 2025 11:17pm
Thumbs Up You can buy direct, that’s what I did.
Dave who runs Ashcroft knows his stuff. Very Happy ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1067192 6th May 2025 11:45pm
keith
C90,,, 1pair now purchased direct. 👍
Post #1067193 7th May 2025 12:05am
Ianh
Corroless do a glass reinforced chassis in one ( corroless QDR ). It dries a semi Matt black, but that Matt is more of a very dark grey in my opinion. You can top with a gloss black RF16 for a rock hard paint job.
https://www.thomas-graham.co.uk/paint/corr...s-topcoats
Both available in spray cans or tins.
Post #1067212 7th May 2025 10:26am
keith
RF16 purchased, in ‘Jet Black’
Thanks IanH.
Post #1067320 8th May 2025 11:24pm
fogbank
I wasn't impressed with it at all, its pretty soft.
I'm going with Jotum 2pack this time on anything, having it blasted or sanded properly with 80 grit 1st
Post #1067333 9th May 2025 9:50am
SimonR
I wondered if you might be interested in this.
I have 4 Sacrificial Anodes attached to my 90. Two on the rear cross member and two on the bulkhead outriggers.
They are intended to provide some corrosion protection to boat hulls - but are also fairly effective on vehicles. I've used this approach before. While it's not totally conclusive, both my bulkhead and rear cross member remained largely corrosion free for the 18 years I owned my 110. The anodes meanwhile completely corroded away after about 10 years so I replaced them.
They only seem to protect a short distance away from the anode itself (due to electrical resistance). I've added electrical braided straps connecting the bulkhead to the anodes to improve the connection.
Will it work this time round? Ask me in a decade!
Post #1068479 26th May 2025 3:50pm
hebdenap1@aol.com
Sacrificial anodes on a Land Rover 😂
Sacrificial zinc anodes only work when immersed in salt water so as to create a galvanic cell between the more noble cathode and the anode. On a GRP boat the anode protects the propeller etc.
They will do absolutely nothing on a Land Rover!
Post #1068486 26th May 2025 5:19pm
