Home > Technical > THE webasto Thread
Page 14 of 16 <123 ... 13 141516>
isacs
Where abouts are people mounting these heaters? Do you have additional ducting to disbritue the heat or just let it blow around?
Post #749124 4th Jan 2019 11:40am
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
As a heads up and has nothing to do with me ( i've just spent £75 from BT! Twisted Evil ) this is on the bay atm
https://www.ebay.co.uk/itm/Eberspacher-or-...SwjiZcJ3Rx
Post #749314 5th Jan 2019 8:33am
Martin
Site Admin
Martin wrote:
I’ve ordered an L322 TTC to have a play with.
Right I can now confirm that the L322 TTC heaters can't be triggered using only a 12V switch. They have an interaction with the HVAC controller in the car over the BMW-spec K bus which allows them to start Sad
HOWEVER I have just reprogrammed mine and it now fires up from a 12V switch - no HVAC needed. Absolutely over the moon Mr. Green
Now just to get the rest of the bits to mount it Big Cry  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #753359 23rd Jan 2019 2:03pm
drakes
United Kingdom 2004 Defender 90 Td5 HT Auto Belize Green
Martin
How did you manage to reprogramme and also do you think it would be possible to programme one to RR spec if sourced from another vehicle as I am sure some on FFRR would like to do that
Post #753368 23rd Jan 2019 2:24pm
Martin
Site Admin
With the Webasto software and a lot of messing about. Technically it'd be possible to make one RR spec but I've obviously not done it yet... Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #753375 23rd Jan 2019 3:14pm
excossack
I have been considering a Thermotop to pre-heat/give me warm air from cold.
Looking at this thread you can purchase a ThermoTop C with a pump, add the wiring and a controller on the dash as well?
Rover 75 ones appear to be quite popular. The Thermotops I have seen tend to just be the body and a pump, so is this just a case of
Mount the heater
Divert the flow of the water into the pump
Add fuel source
Add some power and a switch to run the heater and off you go?
For those who have gone down the route with a TD5 and a 2nd hand thermo top with a pump how have you done this? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #753388 23rd Jan 2019 3:55pm
grafty99
Martin, could the thermotop v be altered to be 12v triggered?
If so I would be EXTREMELY interested Whistle 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #753486 23rd Jan 2019 9:33pm
chopcat
Wales 2000 Defender 90 Td5 CSW Java Black
Im not sure of the advantages of are of heating the engine over heating the cab, so i went for an ebersbacher mounted in the rear over the rear wheel, ducted into the front and rear with a dip tube into the fuel tank.
It has been brilliant.
Maybe will add a timer or remote operation but for now just pop out and turn it on before going out. The main reason for fitting was i sit in the back operating radio so it keeps me toasty for the cold nights.
Tc
Post #753536 24th Jan 2019 7:41am
excossack
I was thinking of both. One to preheat the engine so I have warm air from cold and then one for rallies when sat around waiting for action or sat in a WRC stage for best part of a day. (maybe radio operating in the future) 1999 Defender TD5 110
Regards
John M0VAZ
Post #753545 24th Jan 2019 8:45am
chopcat
You dont need to pre heat the engine to warm the cab with a warm air system. So the only real advantage I can see is reducing wear on the engine when starting from cold. As the defender has been made for that sort of use I have not bothered with block heating on mine. On the D4 it is another matter and I have.
T
Post #753553 24th Jan 2019 9:57am
Martin
Site Admin
This would be the holy grail I think, but I'm not aware of an application of the TT-V which is 12V triggered Sad  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #753559 24th Jan 2019 10:41am
grafty99
That's a shame, I was given a brand new one with exhaust, intake and coolant pump. I was hoping to get it going with an oval timer triggered by a cheap RF relay. Obviously a software change would be a much neater option Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #753568 24th Jan 2019 11:05am
Martin
Site Admin
There's an aftermarket 12V -> WBUS converter available on eBay for about £35 (cheaper than the Oval timer).  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #753569 24th Jan 2019 11:07am
TJH1985
Martin - What software do you need to flash them?
Mines been hammered ever morning this week, its nice to come out to a warm and defrosted defender Mr. Green
Post #753580 24th Jan 2019 11:26am
grafty99
Could you post a link please Martin? Can't find it via the keywords I've tried Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #753593 24th Jan 2019 11:55am
