Home > Technical > THE webasto Thread
Page 13 of 16 <123 ... 1213 141516>
dgardel
Italy
Look at here:
https://svkbzq.dm.files.1drv.com/y4mJ8mfzq...amp;psid=1 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #743639 2nd Dec 2018 10:35pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
After reading all of the thread, i can see a 2nd hand unit from a rover 75 should be a straight forward enough jobby for a defender ( simple wiring )
Does anyone have any experience fitting thermo tops from any other Land Rover range ( ie Disco or RR )?
There are a few 2nd hand LR units on the bay and funds are running low to go and buy a new one
Post #748812 2nd Jan 2019 10:03pm
Martin
Site Admin
The Freelander 1/L322/R75 one can be started or run with a simple switch or remote.
The D3/RRS one needs a WBUS communications bus controller to operate it. There are some relatively cheap third party controllers or Webasto options.
I sell lots of the connectors for both types in the site shop: www.defender2.net/shop  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #748817 2nd Jan 2019 10:14pm
Badger110
Cheers martin Thumbs Up
There are some refurbed units on the bay ( Type C universal ) as well as a L322 unit ( Type C )
I'll make some enquiries and i'll become a customer if i need some connectors Thumbs Up
Post #748819 2nd Jan 2019 10:20pm
TJH1985
Mines from a peugeot 807 / Citroen C8, they come mounted on a bracket complete with water pump, fuel pump, exhaust and air filter and don’t seem to sell for much. Simple +12v to fire it up.
Mines wired up with manual switches in the car for Heater & Fan and a controller for remote start via text Thumbs Up
Easily the best modification I’ve made. I’ve added a few pics to my thread.
Post #748833 2nd Jan 2019 11:06pm
Badger110
Good find TJH Thumbs Up
Post #748846 3rd Jan 2019 7:00am
TJH1985
Hey Martin,
How do you start a L322 unit with a simple switch? I couldn’t get ours from a TDV8 to fire manually off the car without BUS. Am I missing a trick, would be great for testing Mr. Green
Thanks,
Tom
Post #748854 3rd Jan 2019 7:44am
Martin
Site Admin
Switching Pin 1 of the 6 pin plug to 12V should start it - same as FL/75 unit.
Do you know what year L322 your Thermo Top is from?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #748864 3rd Jan 2019 10:13am
TJH1985
It’s a 2008, and doesn’t fire with the +12 how strange. The +12v is how we trigger it on the Defender.
Post #748868 3rd Jan 2019 10:32am
Martin
Site Admin
That's odd, as the factory L322 installation uses the pin 1 connection for the Telestart (remote fob) operation.
2015 D90 XS SW
Post #748871 3rd Jan 2019 10:44am
TJH1985
I have telestart which works, so must have been user error Embarassed I will check that out, in the end it was an easy fix as the circulation pump had failed so it was shutting down on temperature.
Post #748875 3rd Jan 2019 11:11am
Martin
Site Admin
I’ve ordered an L322 TTC to have a play with.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #748967 3rd Jan 2019 7:29pm
Badger110
So does that diagram work with a 2002 - 2005 L322?
Post #748980 3rd Jan 2019 8:08pm
Martin
Site Admin
As far as I can see, all the L322 FBHs are wired the same.
I have come across this tonight: https://www.fullfatrr.com/wiki/FBH
This suggests the L322 Thermo Top sends a message out to the aircon ECU (ATC), which it needs a reply to in order to start up when using pin 1 to trigger it Sad  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #749064 3rd Jan 2019 10:42pm
TJH1985
I just had a look in the workshop manual and I have highlighted this in the past which seems identical to the wiki:
When parked heating/ventilation is selected on with the remote handset, the request is received by the FFBH receiver via the TV antenna and TV antenna amplifier. The FFBH receiver relays the request as a hardwired signal to the FFBH control module. On receipt of the request, the FFBH control module sends the request to the ATC module and the instrument cluster on the K bus. Parked heating/ventilation then operates as detailed above.
On receipt of the messages:
The climate set indicator on the TSD panel flashes at 2 Hz to indicate that parked heating/ventilation is active.
If the ambient temperature is less than 5 °C (41 °F), the GEM activates the door mirror heaters for 3 minutes.
If parked heating is activated, the ATC module:
- Energizes the changeover valve.
- Sends a K bus message to activate the FFBH.
- Operates the blower at speed 1.
- Opens the windscreen distribution doors in the heater assembly and closes the face and footwell doors.
If parked ventilation is activated, the ATC module: - Operates the blower at speed 1.
- Opens the face level distribution doors in the heater assembly and closes the windscreen and footwell doors.
Seems the car is very much in control of the whole operation. Shame as they are easy units to find.
Post #749074 3rd Jan 2019 11:43pm
