![]() | Home > Technical > THE webasto Thread |
| T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101
nope! a few gentle taps and the ring undoes with ease. no need for fancy tools |
| Phoenix90 Member Since: 04 Mar 2012 Location: Cornwall Posts: 377
Ideal, thanks
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
to remove the senders is pretty easy, a forum member has fabricated a tool (like the land rover one) that allows you to torque it back to the correct settings
Marcus, the pumps have built in filters
| cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336
two pieces of one inch bar welded together with a nut - not very pretty but does the job - an sure a man with a name like T1G UP could improve on the welding!! Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8493
and? Cheers
strange isn't it James, it's as though Marcus has a day job |
true, but we spoke a week ago sat about it and i was wondering how he had got on then, but i did hear the truck had some TB issues so maybe hes been truckless so not progressed with this one. Cheers
you're right James, he was driving about in a FFRR. We need an update
This week I dropped my tank, sorted out the pipe etc. and all the other bits turned up form Turkey. Unfortunately, despite being well aware of the risks, it seems I have bought a heater that won't fire into life even using the oval time with a bus output
Does anyone know if it is possible jsut to get a replacement PCB that will allow it to operate with just a 12v+ on the signal wire as the unit itself is only a year old and in really good nick |
that's a shame Kris. is there an on-board cmos battery on the board ? if there is, have you taken it off and on again?
do you get any sounds ? does the pump start up ? I have another idea but I'll PM it. |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
You need this one!! http://www.ebay.co.uk/itm/Aftermarket-cont...mp;vxp=mtr I placed one in a mate's Webasto and it works better than the original Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
Thanks dgardel! I'll order one tomorrow, looks the perfect solution! |
| All times are GMT |
