![]() | Home > Technical > THE webasto Thread |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
nope! a few gentle taps and the ring undoes with ease. no need for fancy tools ![]() |
Phoenix90 Member Since: 04 Mar 2012 Location: Cornwall Posts: 377 ![]() ![]() ![]() |
Ideal, thanks
to remove the senders is pretty easy, a forum member has fabricated a tool (like the land rover one) that allows you to torque it back to the correct settings
Marcus, the pumps have built in filters
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 ![]() ![]() ![]() |
two pieces of one inch bar welded together with a nut - not very pretty but does the job - an sure a man with a name like T1G UP could improve on the welding!! ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8250 ![]() ![]() ![]() |
and? Cheers
strange isn't it James, it's as though Marcus has a day job ![]() |
true, but we spoke a week ago sat about it and i was wondering how he had got on then, but i did hear the truck had some TB issues so maybe hes been truckless so not progressed with this one. Cheers
you're right James, he was driving about in a FFRR. We need an update
This week I dropped my tank, sorted out the pipe etc. and all the other bits turned up form Turkey. Unfortunately, despite being well aware of the risks, it seems I have bought a heater that won't fire into life even using the oval time with a bus output
![]() Does anyone know if it is possible jsut to get a replacement PCB that will allow it to operate with just a 12v+ on the signal wire as the unit itself is only a year old and in really good nick ![]() |
that's a shame Kris. is there an on-board cmos battery on the board ? if there is, have you taken it off and on again?
do you get any sounds ? does the pump start up ? I have another idea but I'll PM it. |
You need this one!! http://www.ebay.co.uk/itm/Aftermarket-cont...mp;vxp=mtr I placed one in a mate's Webasto and it works better than the original Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
![]() ![]() Thanks dgardel! I'll order one tomorrow, looks the perfect solution! |
![]() ![]() ![]() ![]() ![]() IID Pro MV License |
