Home > Technical > THE webasto Thread
Page 4 of 16 <123 45 ... 141516>
T1G UP
ickle wrote:
I think this is the filler adapter TIG suggested
https://sales.butlertechnik.com/l-rover-de...pipe-20300
But they list lots of T pieces too so someone must fit them, I can't think of a reason why they wouldn't work, plus you would receive a filtered supply too....
Yes, there are no T pieces required. straight out the side pipe, inline filter, pump and away to the webasto. There around £25 aswell! not sure what i'm doing yet, still looking at mounting places / options etc
Post #170926 26th Sep 2012 9:08am
I looked at the "bean can" solution but it leaves the pipe quite exposed to stones etc thrown up from the rear wheel, maybe put a guard in front ?
Post #171108 26th Sep 2012 8:26pm
T1G UP
For me its the tank job.
Post #171146 26th Sep 2012 9:30pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
I'm going to look at making a 'bean can' and some stainless steel shield. But will probably use ss tubing to route alot of the fuel line anyway.
Post #171147 26th Sep 2012 9:34pm
jst
i think tank is best BUT i am interested to know when LR stopped putting the bit in that needs to be cut off to allow the pickup fitting into the tank! yours may not be a straight fwd fit marcus. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #171153 26th Sep 2012 9:53pm
T1G UP
ah good point.
Post #171207 27th Sep 2012 8:49am
to be honest, it's worse thinking about dropping the tank than actually doing it. Two of us did it in a morning.
Post #171580 28th Sep 2012 1:54pm
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
T1G UP wrote:
ah good point.
Might be worth while calling Martin at D44 they have just done mine and now have a way of installing the pickup which is also approved by Webasto ! 2007 TD5 90 Hard Top
Post #171631 28th Sep 2012 7:18pm
dgardel
Italy
my choice
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #171657 28th Sep 2012 8:45pm
@daniele Thumbs Up
Post #171698 28th Sep 2012 10:37pm
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
bpman wrote:
@daniele
same here
Post #171739 29th Sep 2012 8:49am
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
I had a look at the Entreq website, the English version is messed up, but google translate of the German version shows a modified version of the fuel connection pipe for the 2.2.
Post #171864 29th Sep 2012 8:58pm
like cobs, I bought the genuine webasto low profile pipe for the fuel pickup, well engineered, stainless and probably still cheaper that a piece of German plastic pipe and a couple of jubilee clips Rolling with laughter
https://sales.butlertechnik.com/vehicle-he...-41s45017a
Post #171942 30th Sep 2012 8:08am
Inigo
Yes, it does look better, but I'm not sure it fits the 2.2. The 2.2 seems to have an existing spigot on the fuel tank assmbly (to the right of the electrical connector - number 5).
I can't find a picture of the unmodified 2.4 fuel tank filler bit to see how that looks, do you have to drill a hole to fit the pickup?
Post #171990 30th Sep 2012 10:33am
Inigo
On a side note, while researching this I found a cheaper alternative to the Land Rover fuel tank wrench (£85).
http://www.amazon.co.uk/Laser-4768-Fuel-Se...B0034HNS96
Don't know how good it will be, but for a one off, it will probably do at £15.
Post #171991 30th Sep 2012 10:34am
