![]() | Home > Technical > THE webasto Thread |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
Yes, there are no T pieces required. straight out the side pipe, inline filter, pump and away to the webasto. There around £25 aswell! not sure what i'm doing yet, still looking at mounting places / options etc |
For me its the tank job.
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 714 ![]() ![]() ![]() |
I'm going to look at making a 'bean can' and some stainless steel shield. But will probably use ss tubing to route alot of the fuel line anyway. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8362 ![]() ![]() ![]() |
i think tank is best BUT i am interested to know when LR stopped putting the bit in that needs to be cut off to allow the pickup fitting into the tank! yours may not be a straight fwd fit marcus. Cheers
ah good point. |
to be honest, it's worse thinking about dropping the tank than actually doing it. Two of us did it in a morning.
Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582 ![]() ![]() ![]() |
Might be worth while calling Martin at D44 they have just done mine and now have a way of installing the pickup which is also approved by Webasto ! 2007 TD5 90 Hard Top |
my choice
![]() Click image to enlarge Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
@daniele
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 ![]() ![]() ![]() |
same here |
Inigo Member Since: 13 Nov 2011 Location: Kent Posts: 627 ![]() ![]() ![]() |
I had a look at the Entreq website, the English version is messed up, but google translate of the German version shows a modified version of the fuel connection pipe for the 2.2.
![]() Click image to enlarge ![]() Click image to enlarge |
like cobs, I bought the genuine webasto low profile pipe for the fuel pickup, well engineered, stainless and probably still cheaper that a piece of German plastic pipe and a couple of jubilee clips
![]() https://sales.butlertechnik.com/vehicle-he...-41s45017a |
Yes, it does look better, but I'm not sure it fits the 2.2. The 2.2 seems to have an existing spigot on the fuel tank assmbly (to the right of the electrical connector - number 5).
![]() I can't find a picture of the unmodified 2.4 fuel tank filler bit to see how that looks, do you have to drill a hole to fit the pickup? |
On a side note, while researching this I found a cheaper alternative to the Land Rover fuel tank wrench (£85).
http://www.amazon.co.uk/Laser-4768-Fuel-Se...B0034HNS96 Don't know how good it will be, but for a one off, it will probably do at £15. |
