Home > Technical > THE webasto Thread
Page 7 of 16 <123 ... 678 ... 141516>
jst
its done and it works! Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #177174 19th Oct 2012 5:21pm
mobilecentre
We cannot compete with some of the pricing on Thermo top C's you guys find but do have an alternative for Puma mounting which is under the n/s wing on RHD cars using our own custom bracket Thumbs Up
Post #177284 19th Oct 2012 9:50pm
dgardel
Italy
jst wrote:
^^ thats my understanding too. i dont want the inside warm, i just want an engine pre warmer. but as i understand it if its plumbed into the the actual heater valvle block if the heater is off (ie on cold) then the coolant wont flow through the webasto?
i intend to fit it between the egr return and the return from to the engine.
ie between the T piece that goes to the engine coming from the heater, and egr return, that way the webasto will have flow regardless of what the heater valve is on.
A - When the heater is ALL OFF the cooling water enter from "3" and go directly to the "4" (no flow on heater).
B - When the heater is ALL ON the cooling water enter from "3" and go trough "2", heater matrix, "1" and, at least, return t the engine circuit "4".
In the "middle" regulation is a "mix" of A and B
is it clear?
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #177292 19th Oct 2012 9:56pm
dgardel
Italy
Big Cry Big Cry Big Cry
When I studied my installation I tried the same possibility also, but no room here for LHD Puma (clutch pedal/pump). Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #177299 19th Oct 2012 10:04pm
jst
is it clear?
perfect, thank you
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #177312 19th Oct 2012 10:48pm
jst
thats where mine has just been fitted. bloody tight on the intake cowl though. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #177313 19th Oct 2012 10:49pm
James - make sure you leave enough room behind the wing - as you know these units get hot Thumbs Up
Post #177344 20th Oct 2012 8:11am
yes, but on LHD you can use BMW X5 installation kit ... like I did Thumbs Up
Post #177346 20th Oct 2012 8:12am
dgardel
Italy
Have you photos/infos? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #177347 20th Oct 2012 8:15am
jst
theres about a 30mm air gap around it, seems ok so far! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #177362 20th Oct 2012 9:18am
T1G UP
um think i've got the wrong dip tube for the tank.
what have you fitted? mines 300 mm long? seems to short.
The loom i ordered from Turkey off Ebay along with a few other bits has arrived. Very good service.
So far i've spent £180. i have a second set of plugs to make another loom.
this is great!
Post #177455 20th Oct 2012 5:01pm
jst
i ordered the one off the link posted before, i had to cut 1/3 - 1/2 of it off. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #177502 20th Oct 2012 8:03pm
jst
https://sales.butlertechnik.com/vehicle-he...-41s45017a
i used this one.
you may get away with a 300mm one, i can measure how much i cut off! have the ends but cant remember how much i left on. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #177503 20th Oct 2012 8:05pm
jst
just to say the thermo top C has been in since Sat and i am very pleased with it.
with 9 deg amb and no internal heating, 20mins or just under brings it up to 58 deg or so, i have mine plumbed to heat the block first and it works for what i want.
Airtop has been in for 10 days now (ish) and is working a treat, i may move the air intake (comb side) at one point, but it will suffice for now.
Just to say a big thank you to everyone on here for their help and advice in the fitting, greatly appreciated. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #178403 23rd Oct 2012 8:06pm
T1G UP
good day today. dropped tank, fitted line and pump. tried to fit loom and webasto bit failing light and enthusiasm beat me.
easy enough although i did have a moment when the fuel gauge wouldn't go back up Big Cry did after 30 seconds Thumbs Up loom to fit and webasto unit.
Post #179573 27th Oct 2012 8:27pm
