Home > Puma (Tdci) > Puma fuel bleeding pump
Page 10 of 11 <123 ... 91011>
ozy013
Australia 2010 Defender 110 Puma 2.4 SW Rimini Red
Ive also been wondering in regards to this green cap and valve, but never got around to asking the question. Can't seem to find any mention of it in the workshop manual, just wondering if it is only an Aussie thing.
Maybe, as mentioned before, its to bleed the air out of the lines as you draw the fuel up the low pressure side, similiar to the one on the Sealey tool.
Post #772900 13th May 2019 9:52am
MK
I have the same here. I have used it a couple of times to get the air out. It it was a 2 people job. One blowing air through the filler and the other pushing the needle valve.
Now I have my alliexpress manual pump. Puma 110" SW
Post #772930 13th May 2019 1:42pm
MGRGPGBG
United States 2009 Defender 110 Puma 2.4 SW Alpine White
I made a hand bleeder from the parts that were described in the thread and it worked perfect. I wanted to keep it somewhere on the truck just in case I ever need it when not in the garage. Since it smells of diesel I do not want to keep it inside the truck. Does anyone store it under the bonnet somehow?
Post #774056 20th May 2019 5:27pm
Kevlar
Czech Republic 2010 Defender 90 Puma 2.4 SW Santorini Black
Hi All
I have created a bleeding bulb as described in this thread, I connected to the female fuel supply line (the blue connector) and I pumped a liter into a bottle and all was good.
When I connect the bleeding bulb inline (connected to the fuel pump) its impossible to pump.
It like the fuel pump is closed and wont allow fuel in.
Also when I turn the engine over I don't see any fuel flow through the bleeding bulb pipes.
Should it pump freely through the pump ?
Any advise please
Thanks
Kev
Post #871282 4th Dec 2020 1:51pm
Joakim Svensson
Sweden
Same thing here
Post #1066235 24th Apr 2025 8:06pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
When connected inline, you have to open the tool’s bleed valve to allow flow.
Post #1066271 25th Apr 2025 1:25pm
Joakim Svensson
Sweden
Fuel system is free of air but it seems like the rail dont have fuel.
New filter, almost 4 liters of fuel when bleeding the system but no start!
Nanocom shows some codes
U3000
B1A75
B1A81
P1602
U0401
Is the HP pump driven with chain?
Crank sensor works, swaped it from the one on my car to the non starter and my car starts with the other sensor.
It like the HP pump dont get signal or something…immo?
Post #1066289 25th Apr 2025 4:49pm
jbcollier
It was running fine, you changed the filter, and it won’t start? Or?
Post #1066291 25th Apr 2025 5:20pm
Joakim Svensson
Sweden
Busted a fuel line so system went out of fuel
Post #1066341 26th Apr 2025 6:30am
jbcollier
How are you bleeding the system?
Post #1066380 26th Apr 2025 2:41pm
Joakim Svensson
Sweden
On return line both on pump and quickconnect near fuel rail!
7 liters and still air
Post #1066385 26th Apr 2025 4:11pm
jbcollier
What are you using to bleed the system?
Post #1066422 26th Apr 2025 11:12pm
Joakim Svensson
Sweden
Have tried with a ”handpump” and an oilsucker thing as everybody else does but i dont get fuel up to the rail.
Have to change fuel lines to see if they are leaking.
Post #1066440 27th Apr 2025 8:26am
jbcollier
So you are using this:
There are no instructions that actually tell you how to use this tool. You have to open the air bleed for it to work. Otherwise the fuel won't flow.
Alternatively, you can hook up a vacuum to the system bleed valve (green cap). You'll have to rig up an adapter that depresses the one-way valve. A bicycle pump hose for a schrader valve would do the job nicely.
Post #1066460 27th Apr 2025 2:06pm
HardCharger
Speaking of green caps, mine is missing. Can we get a replacement or spare of this? I'm not comfortable with the valve exposed to the world. No Better Friend, No Worse Enemy
Post #1066513 28th Apr 2025 9:36am
