![]() | Home > Puma (Tdci) > Puma fuel bleeding pump |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 823 ![]() ![]() |
I was posting about that connector a little while back as it appears even dealers can't help with a coupling so that it can be used to check your lp fuel side..
The valve unlike a traditional schrader isn't removable...or it certainly doesn't unscrew from the fitting.. I lashed something up so I could check my lp side pressure (on a 2.2 tdci ) using a pressure gauge.. Anyhow from memory I think the thread was an m12 with a 1.5mm pitch ( not able to physically confirm this atm ) so you may be able to find a cap that screws on.. I doubt they will be available without buying the pipework and fitting.. |
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 273 ![]() ![]() ![]() |
A tire valve cap will fit.
What size tyre are you talking about.. it's a m12 thread.. the pitch as I said I think is 1.5mm.. a standard tyre valve cap wouldn't do that..
That's on a 2.2tdci.. |
Thanks for the correction!
M12 x 1.5 female cap Hydraulic hose suppliers carry them in plastic and metal. Last edited by jbcollier on 28th Apr 2025 6:03pm. Edited 1 time in total |
Ive seen a few asking where they could get a cap from so that is handy to know.. easily lost and the cap provides another layer of sealing and preventing back leakage if the valve is iffy...
https://brakequipproducts.com/shop/plugs/b...m12-x-1-5/
https://www.brakeconnect.com/product/female-plug-m12-x-1-5 https://www.pulsarhydraulics.com/buy/product/63000l-06/33700 https://uschydraulics.com/products/metric-...0285380783 https://www.flowtech.co.uk/category-landin...tSku=12103 https://www.fluidairfittings.co.uk/products/non-branded-12103 |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 806 ![]() ![]() ![]() |
Thanks, jbcollier!
