Home > Puma (Tdci) > Puma fuel bleeding pump
Page 11 of 11 <123 ... 91011
andy63
I was posting about that connector a little while back as it appears even dealers can't help with a coupling so that it can be used to check your lp fuel side..
The valve unlike a traditional schrader isn't removable...or it certainly doesn't unscrew from the fitting..
I lashed something up so I could check my lp side pressure (on a 2.2 tdci ) using a pressure gauge..
Anyhow from memory I think the thread was an m12 with a 1.5mm pitch ( not able to physically confirm this atm ) so you may be able to find a cap that screws on.. I doubt they will be available without buying the pipework and fitting..
Post #1066515 28th Apr 2025 10:04am
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
A tire valve cap will fit.
Post #1066526 28th Apr 2025 1:22pm
andy63
What size tyre are you talking about.. it's a m12 thread.. the pitch as I said I think is 1.5mm.. a standard tyre valve cap wouldn't do that..
That's on a 2.2tdci..
Post #1066530 28th Apr 2025 2:03pm
jbcollier
Thanks for the correction!
M12 x 1.5 female cap
Hydraulic hose suppliers carry them in plastic and metal.
Post #1066545 28th Apr 2025 5:33pm
andy63
Ive seen a few asking where they could get a cap from so that is handy to know.. easily lost and the cap provides another layer of sealing and preventing back leakage if the valve is iffy...
Post #1066550 28th Apr 2025 6:00pm
HardCharger
So far, all I've found are M12 x 1.75 female caps. Sad No Better Friend, No Worse Enemy
Post #1066574 29th Apr 2025 1:50am
jbcollier
Post #1066575 29th Apr 2025 2:31am
HardCharger
Thanks, jbcollier! Thumbs Up Bow down No Better Friend, No Worse Enemy
Post #1066665 30th Apr 2025 5:38am
