Home > Maintenance & Modifications > Corrosion Prevention Guide! |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 4990 |
Swings and roundabouts isn,t it. Galvanising can chip especially on edges or where you have to put in a fastener, where as these rock hard paints can be hit with a hammer without causing any damage. They don,t peel and certainly don,t flake... get it on your skin and it's there for weeks, get it on the paint lid edge and you won,t get the lid off again. Instructions are to decant it into your paint pot it Is incredibly strong stuff, think bonding cement rather than paint. Mud sitting in a box section will rot through galv... mud sitting on top of this paint in a box section will never do anything to compromise the impenetrable barrier. I have seen new galv chassis rust in mud trap areas after 5 years. If they had been painted on top of the galv they would have been pretty bomb proof.
10th Apr 2021 9:24am |
Wouldn,t hurt to but not really necessary :thumbsup: |
10th Apr 2021 9:26am |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 |
Any recommendations for DIY ish (farm shed job), I may start building a spare chassis up over the summer. |
10th Apr 2021 9:32am |
How do you mean, "building a spare chassis up". Is this a new chassis? Is it already galvanised or ungalvanised. There are many suitable products on the market, even rubber based stuff you paint farm building metal superstructures with. I like the POR-15 range but there are many on the market, choose also by which will go onto galv if it is already galvanised and if you need it to be UV resistant I.e. Rear crossmember. The picture below is one I have just taken as an example for one of the previous posts, it may not be an example for your question.
Click image to enlarge So think bonding cement not paint. This particular POR-15 comes in two parts like an epoxy, it can be hand painted or sprayed. It takes 3 days to fully go off etc etc... bloody hard stuff and yes you cAn belt it with a hammer and nothing happens. If you are building up an old chassis then I would use the Dinitrol range. You don,t want to put this stuff anywhere near old metal where there is a risk of rust. You are just trapping the rust in, as said soooo many times. They don,t stop rust as they claim, they just stop it showing through.... have fun Last edited by Zagato on 10th Apr 2021 10:04am. Edited 1 time in total |
10th Apr 2021 9:47am |
Back for a few pretty pictures. This was very nice, came in for a comprehensive clean, polish, engine bay basic detail etc...
Click image to enlarge Click image to enlarge Click image to enlarge Top tip on those engine ancillaries that are now deteriorating! Arm yourself with a Dremmel and some Autosol, this pic shows the left end bit done and the night and day difference.. spray with ACF-50 afterwards and it will stay shiny... Click image to enlarge |
10th Apr 2021 9:56am |
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 552 |
Galv should not chip off as it should bond with the metal. If it chips or peals then it has not been done correctly. If you drill a hole the only galv that comes off should be taken off with the drill bit. The only time it should come off with a hammer is when the metal deforms. As I said previously, a big advantage with galvanising is it gets into the nooks and crannies, something that paint can't, which is why we use cavity treatment. Galv can't cope with welding as it burns off, but that is the same with paint. I agree that galv can corrode through, it is sacrificial not impenetrable and that must be considered regarding further treatment and ongoing maintenance. An additional layer of tough paint would definitely be an advantage. |
10th Apr 2021 10:32am |
Cheers, it will be a new galvanised chassis. My one is ok for a bit yet but I'd like to have one ready when needed. Mine is pumped full of Lanougard and Dynax UB atm but its also 17 years old and has lived a life. |
10th Apr 2021 10:33am |
The reality is I have worked on many Marsland and Richards Chassis, two of my own from new that had the galv chipped in places on arrival, the same with Ifor Williams trailers and my boat trailers which easily chip, especially on the edges. Agree with the thoroughness of dipping if there are enough holes to ensure the galv gets in all the nooks and crannies, so it doesn,t explode in the process where these air holes are you can spray inside even the smallest of box sections with a 360 dregree spray. Quick, easy and with an impenetrable coating, not a sacrificial one. Job done. I see little point in going to the cost and expense of galvanising something that will rot away in time when you can do a permanent job from the outset at little cost with one of these newer products on offer. The saving cost to the industry alone would be massive. |
10th Apr 2021 10:53am |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10530 |
liking the Saab, Zagato 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
12th Apr 2021 9:20pm |
Pretty pic time. The 110 is 'Bear100's the picture does not do it justice. I have had some pretty modified vehicles in over the last ten years and 900 or so Defenders but I can honestly say Ceri has thrown absolutely everything at this, and done most of it himself, right down to the door handle press buttons. All practical stuff also.
Ceri also the wins first and only prize for cleaning the vehicle. I have some pretty OCD clients which is why they come to me who have a go at getting the mud out of the crevices but this Defender is the only one which has been done COMPLETELY thoroughly . I am currently working on it over a two week period with the mentality similar to working on an Airfix Kit, I.e. Take a small area at a time, take your time and have lots of break from it... I don,t spend too long each day on the work so I keep fresh and motivated. I am in no rush, I give myself plenty of time to do each vehicle, I'm not chasing money or into building empires Click image to enlarge |
16th May 2021 9:11am |
A very nice local Autobiography
16th May 2021 9:13am |
This one all the way from Spain, a left hooker that will live in Switzerland...
16th May 2021 9:16am |
This was nice, full on interior and another which left with a wash, 3 layer of wax and engine bay detail
Click image to enlarge Japanese import and I am now doing bikes I.e. Detailing and ACF-50 treatment Click image to enlarge Click image to enlarge Bookings 07484160070, CCalvert@CCAutomotive.co.uk |
16th May 2021 9:18am |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7875 |
Nice update and great work!!
Always makes me feel like I'm neglecting mine James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
16th May 2021 10:24am |
