Home > Maintenance & Modifications > Corrosion Prevention Guide!
Page 66 of 89 <123 ... 656667 ... 878889>
Zagato
What do they call a herd of Defenders?
This is "Captain Slows" 14 plate which I did four years ago and it is in for a touch up, although we have decided to give it the full works again as recommended by Dinitrol. It still looks really good however showing how well the treatment works... will take a pic once I have cleaned it properly! Like the wheels Very Happy
Post #841731 4th Jul 2020 11:53am
mk1collector
I believe a heard of defenders is called an insanity! Ray
My build thread
Post #841738 4th Jul 2020 12:36pm
90 Dreamer
Bankruptcy.......... Big Cry
Post #841740 4th Jul 2020 12:44pm
Zagato
Laughing
I think a Pride of Defenders should be the official description Wink
.... or maybe a Drove!
Post #841754 4th Jul 2020 2:47pm
Zagato
Nice straight Discovery, I have a rust free V8 Japanese import Discovery coming in next month... Cool
This is straight and honest also, never been treated but holding up very well as it isn't used much.... towing a horse box and annual shooting trips to Scotland. It comes from a farm a few hundred yards up the road from me. I should be getting another in which is two doors down from me also... Land Rovers everywhere around here Very Happy
Post #843237 12th Jul 2020 8:50am
Zagato
Got to love a Hilux, chassis very good on this Cool
This is 'Ronins' just in for a top up bright and early this Sunday morning and it is still VERY clean, I did this a few years ago as a hard top so was nicely shocked by the impressive conversion. Why wouldn,t you? I ran a 1960's series ll like this as a daily driver for three years... great fun. This is a really nice conversion.
Post #844695 19th Jul 2020 10:35am
s55shh
Whats the opinion of our guru on this Lanoguard stuff advertised at the mo?
Post #844771 19th Jul 2020 8:35pm
Zagato
You are too kind but Guru Embarassed I had talks about using Lanoguard from an idea I have which is in a different direction to the current work which maybe something I might follow up on if work ever gets quiet (it hasn't for the last ten years Wink ) I don,t really want to start such a venture however, I am quite happy to plod on with my work at my own enjoyable pace, my days of building small "empires" are over!!
The reason I don,t use it at the moment as said previously is that it is clear so competes directly with Dinitrol Corroheat which is unbeatable at the moment for cars that want to show off a new or very good condition underside. Most clients however want a coating like Dinitrol 4941 that provides a smart, Matt "black" coating. Lanoguard cannot do this but it does have a place for some circumstances. I would be more than happy to use it upon request.
Post #844781 19th Jul 2020 9:49pm
EVdV
Belgium 2006 Defender 90 Td5 ST Java Black
My 2006 td5 is in need of some attention aswell. The chassis has been done and is in good nick, but the rear crossmember is showing signs of rust coming through. It was brush painted with an unknown product by the previous owner and showed small rust spots, after I removed the NAS step there was some more underneath so time for preventive measures. Wire brush untill bare metal, por 15, red ocxide paint or ... What would be the best step in this case?
The footwells and inner side of bulkhead are sowing some rust aswell. Hand wire brush als dinitrol rust converter, followed by acf40 to slow down the rust for now?
Post #848850 9th Aug 2020 2:48pm
Zagato
Apologies for the late reply 'EVdV' I have been off grid for a while! You have probably found the answer to the most commonly asked question about a Defender regarding a rusty rear crossmember, numerous in depth posts on it all over the net, on this forum and in this thread with members adding there own preferences with pictures. The only thing I would add is forget red oxide paint, it is just an ancient sacrificial layer, does not actually stop or cure rust, ok for RSJ,s and barns!! Also ACF-50 is ideal for getting to the areas you cannot guarantee you can get all the surface rust off or the other bits maybe you have pictured although you cannot paint over the top of it Thumbs Up
Something completely different for this weeks work. This is the actual Earls Court Motor Show model Cool
Post #849719 13th Aug 2020 12:22pm
EVdV
Thanks Zagato, I found the info indeed. Would you just treat the inside of the bulkhead with acf50 because it's unknown if there is rust inside? If I knew it was all good I'd dinitrol it, but given the interior side of the bulkhead is starting to rust, there is a good chance the inner box section is rusting aswell I presume.
Post #849738 13th Aug 2020 1:32pm
Zagato
Yes Thumbs Up
Post #849751 13th Aug 2020 2:44pm
L110CDL
WOW that is a rare beast, thanks for the pic Zagato Cool Clayton.
Keeper.
Post #849858 13th Aug 2020 9:25pm
Varyag
Sweden
Hi,
Since there seems to be quite some experienced people here, I figured I'd go ahead and ask. I'm trying to rust protect my Saab 9-3 with Dinitrol (I bought both ML and 4941/CAR), and the question is whether it's enough to just put ML as an underbody coating where there's not all that much spray as far as I know, like where the shock absorber mounts to the body above (but on the inside of) of the wheel. The plastic inner wheel well liner doesn't cover this part. Originally, this part wasn't protected at all, just some regular paint from what I can tell.
The reason why I'm hesitating is I just don't want to put on more stuff than necessary, since I'm a beginner at this and I fear that 4941 might obscure any corrosion. But maybe the elements would make this a lost cause, even though I'll only drive on decent roads, though including lots of slush, snow and salt?
It looks like this, and I'm talking about the "bracket" with the two bolts that fastens the absorber to the body (as well as the area of the body that it's fastened to), though mine had a thin paint layer on it in roughly the same color as the car: https://blog.fcpeuro.com/hubfs/Imported_Bl...rShock.jpg
Post #850411 16th Aug 2020 9:57pm
Zagato
Hi Varyag, welcome to the forum, especially as you are from Sweden and have a SAAB Very Happy It,s all SAABs, LandRovers and the occasional Supercar here at my place this morning. Laughing Oh and a little Swedish Marieholm IF Boat to complete the theme.
As you suggest Dinitrol ML is not resilient enough as an exposed top coat, it Is purely to help adhesion of 4941 and as a thinner cavity wax. For anything which has no rust but you want protected use Dinitrol Corroheat, one layer looks as though you have put nothing on, two layers and more and it becomes opaque. I would put two to three layers on your shock absorber mount, not cheap but superb stuff. It will go hard in time, and you can put it on anything hot without problems as it was designed as an engine detailer. Spray away Thumbs Up
Post #850434 17th Aug 2020 8:48am
