Home > Puma (Tdci) > 2013 Defender PUMA 2.2
Page 3 of 3 <123
Ianh
Ask the garage/ dealer What fault codes are showing, that will help the experts on here assist in localising the cause. Note I’m assuming some fault codes must be there.
It could be any of the things people have highlighted, for instance I had similar issues with going into limp mode. Then real trouble starting. Left for a day would start but not instantly. Then if stopped would not start again.Turned out to be the EGR on my 2.2. But I quickly identified likely cause from fault codes and searching here.
Note:- I also got that slight whistle
The problem with the EGR sticking happens from about 50k miles from what I can see. What miles are on your defender 2.2 ?
Ps I changed the EGR myself with great advice from a member. Not technically difficult but incredibly frustrating due to access to nuts , bolts , studs and pipe clips. Which reminds me I must write up a how to on that one as there is one for the 2.4 but not 2.2.
Post #819177 11th Mar 2020 9:10pm
JimG
Hi, unfortunately they have told me that no fault codes have been registered. They think it’s a timing issue but that’s more of an educated guess I think. The vehicle just won’t start but she will crank all day. Once you use a bit of quick start she starts up and runs fine. The told me that they changed all the probable sensors. Fuel filter, housing and lines have been changed. Fuel pump, injectors etc have been changed previously. I have checked the relays and and looked for obvious signs of loose wiring etc. The EGR was removed previously and she has had an ECO Remap by the same people who done the injectors, the same people who are currently looking at the vehicle. The whistle sound like and electronic whistle/ constant ping! Also thanks Joe-130 I have passed your information on.
Post #819254 12th Mar 2020 11:45am
G4UJS
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
Hi Jim,
What a nightmare for you!!
Is this at a. Land Rover Specialist?
Rob
Post #819256 12th Mar 2020 11:53am
JimG
It is with a garage that work with Defenders but not a Land Rover dealership.
Post #819261 12th Mar 2020 12:08pm
G4UJS
Have they fixed it yet?
Post #819971 17th Mar 2020 12:58pm
Clemmo
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Guessing this must be resolved?
Question Make today a little better than yesterday but not so good as tomorrow....
Defender 90 HT............Pangea Green
BMW X3 Msport............Carbon Black
Mini Electric................Grey. (wow!)
MGB Roadster……..........Vermillion
Honda Benly CD200....Maroon ------------- Chausson 98.........7.5m of fun
Post #820080 18th Mar 2020 11:00am
JimG
Sorry All, working at sea at the min. No it still hasn’t been resolved. LR changing the high pressure fuel pump tomorrow.
Post #820133 18th Mar 2020 8:27pm
JimG
Hi All, just got word this evening that the garage thinks they have sorted the problem. The problem seems to have been a stretched timing chain causing the timing to be slightly out! Fingers crossed!
Post #820417 20th Mar 2020 9:11pm
G4UJS
Thumbs Up
Post #820446 20th Mar 2020 11:15pm
Clemmo
Blimey...that would worry me.
What’s the cause of the stretched chain??...usually very high mileage or no maintenance.
No good just replacing the chain... many checks are required.
Really hope the warranty covers everything you need
Clemmo Neutral Make today a little better than yesterday but not so good as tomorrow....
Post #821066 24th Mar 2020 8:58pm
JimG
Handed the vehicle back and got a refund. It had trouble written all over it! Onwards and upwards! Hope the next one is a bit better. Thanks for all the responses! Thumbs Up
Post #821070 24th Mar 2020 9:15pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
What mileage was it out of interest?
Post #821118 24th Mar 2020 11:37pm
JimG
Around 98000 miles.
Post #821126 25th Mar 2020 6:44am
Morepower
New Zealand
They do say 100000 miles is usually time for a new chain...
Regards
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #821152 25th Mar 2020 9:31am
Page 3 of 3 <123
