Home > Puma (Tdci) > 2013 Defender PUMA 2.2
Page 1 of 3 123>
JimG
HI All, this is my first post and I am just wondering can you help me. I just bough a defender on yesterday and after bringing it home it has failed to start. The key fob seems to work and I have changed the battery now just in case. The engine turns over but will not start. checked relays under the seat and checked the fuses. wiring also seems to be ok. I also notice that with the bonet open i can hear a faint whistle/alarm with the key in.
Jim Big Cry
Post #817737 1st Mar 2020 4:49pm
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
Any fuel in the tank Jim?
Did you drive it home or was it transported?
Did it start up ok for you before you did the deal?
Separate immobiliserf fob?
Have you tried both LR fobs?
Post #817754 1st Mar 2020 6:00pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
That must be so massively frustrating.
Have you tried charging the battery?
I think there's a procedure in the handbook to follow when changing fob batteries; might be worth checking those instructions.
(The inertia switch might be worth checking given the symptoms but I would have thought unlikely to be that unless its had a bump.)
Post #817766 1st Mar 2020 6:31pm
Julie
Re: 2013 Defender PUMA 2.2
The faint whistle may be the EGR ... Seems more like a problem related to starting a cold engine : are the glow plugs clean ?
You could monitor the fuel pressure in the common rail, if the high pressure had been damaged ...
it's so frustrating anyway
Post #817771 1st Mar 2020 6:49pm
Check the grounds are good, and battery voltage is acceptable. (Especially battery negative to Gearbox / Transfer box.)
Disconnect the battery, and touch the two DISCONNECTED terminals together.
Then reconnect.
(Negative should be removed first when disconnecting and fitted last when reconnecting.)
Follow the manual for details of the BBUS before you disconnect the battery if fitted.
Once connected all back up, press the fob lock or unlock multiple times rapidly until the red dash led flashes rapidly on the dash and then everything is back to normal.
You may want to check Relays are secure in the Seatbox too.
Beyond this further investigation might be required. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #817776 1st Mar 2020 7:13pm
JimG
Hi, yep I have charged the main battery and it was filled with fuel. The alarm seems to be working ok. I.e., Doors lock and unlock the lights on the dash seem to do what they are supposed to. My gut is telling me it’s a fuel issue. I bled the fuel filter in the wheel arch a little but the fuel seems clean. I am stumpted.
Post #817826 1st Mar 2020 10:14pm
JimG
Hi Steve I will try that in the morning.
Post #817827 1st Mar 2020 10:16pm
JimG
Ok so i checked the fuel filter in the wheel arch and found the top of it covered in diesel impregnated dirt. The outer sheild also shows signs of diesel as if it has been escaping from one or more of the pipes at the top. Is this normal or is it a sign that air has possibly got into the system?
Post #817869 2nd Mar 2020 10:02am
G4UJS
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
are the glow plugs working?
Post #817878 2nd Mar 2020 11:16am
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
Can you nip the filter up a bit more?
Is it leaking when you turn the ignition key to position 2 for 10 seconds?
Post #817880 2nd Mar 2020 11:24am
ickle
Filter & housing should be dry. Check filter is fully tight - Caterham will be along in a minute to further explain Rolling with laughter
Not 100% sure on 2.2 but 2.4 has no pump in the tank and if there's a leak in the system its easier to suck air in rather than diesel from the tank. You will need a priming bulb and associated pipes to bleed it properly.
Post #817884 2nd Mar 2020 12:01pm
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
you mention a whistle is the car alarm working ok have you tried alarming and disarming it also have you two sets of keys if you have try both sets . can you contact the seller
Post #817887 2nd Mar 2020 12:25pm
JimG
Ok the vehicle has been picked up on a low loader and taken to a specialist mechanic. I will let you know the outcome when I know more. Thanks everyone. 👍
Post #817891 2nd Mar 2020 12:43pm
G4UJS
Good Luck, I feel for you, but you will grow to love it!!!
Welcome to Defender ownership!
Regards
Rob
Post #817896 2nd Mar 2020 1:06pm
G4UJS
Hi Jim,
Have they sorted it for you?
Rob
Post #818128 4th Mar 2020 1:24pm
Page 1 of 3 123>
