![]() | Home > Puma (Tdci) > 2013 Defender PUMA 2.2 |
JimG Member Since: 01 Mar 2020 Location: North West Posts: 18 ![]() ![]() ![]() |
Hi, unfortunately they have told me that no fault codes have been registered. They think it’s a timing issue but that’s more of an educated guess I think. The vehicle just won’t start but she will crank all day. Once you use a bit of quick start she starts up and runs fine. The told me that they changed all the probable sensors. Fuel filter, housing and lines have been changed. Fuel pump, injectors etc have been changed previously. I have checked the relays and and looked for obvious signs of loose wiring etc. The EGR was removed previously and she has had an ECO Remap by the same people who done the injectors, the same people who are currently looking at the vehicle. The whistle sound like and electronic whistle/ constant ping! Also thanks Joe-130 I have passed your information on.
G4UJS Member Since: 20 Jan 2019 Location: Shropshire Posts: 226 ![]() ![]() ![]() |
Hi Jim,
What a nightmare for you!! Is this at a. Land Rover Specialist? Cheers Rob |
It is with a garage that work with Defenders but not a Land Rover dealership.
Have they fixed it yet?
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1271 ![]() ![]() |
Guessing this must be resolved?
Sorry All, working at sea at the min. No it still hasn’t been resolved. LR changing the high pressure fuel pump tomorrow.
Hi All, just got word this evening that the garage thinks they have sorted the problem. The problem seems to have been a stretched timing chain causing the timing to be slightly out! Fingers crossed!
Blimey...that would worry me. What’s the cause of the stretched chain??...usually very high mileage or no maintenance. No good just replacing the chain... many checks are required. Really hope the warranty covers everything you need Clemmo ![]() |
Handed the vehicle back and got a refund. It had trouble written all over it! Onwards and upwards! Hope the next one is a bit better. Thanks for all the responses!
JPE Member Since: 19 Nov 2018 Location: South West England Posts: 344 ![]() ![]() ![]() |
What mileage was it out of interest?
Around 98000 miles.
Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630 ![]() ![]() |
They do say 100000 miles is usually time for a new chain...
Regards Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
