Home > Maintenance & Modifications > Rear Half Shaft Replacement
Page 6 of 9 <123456789>
Nitroneil
Just fitted new shafts and drive flanges tonight, along with new pads all round. Took longer to get the front wheels off than it did to replace the rear shafts! Ended up loosening up the front wheel nuts and driving in and out driveway until they loosened. Like a different car now, old flanges were shot. (Just bought the car, have a long list Smile
Post #765584 27th Mar 2019 12:29am
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
I finally got round to fitting the Disco 300Tdi rear half shafts I bought (see page 2 of this thread) to my 2014 110 2.2 van today and can confirm they're a straight swap for the standard two piece ones and a doddle to do.
I used new gaskets but re-used the original bolts, torqued to 65Nm. I'd had an oil leak from the driver's side fixed under warranty, and the dealer clearly hadn't used any thread locking compound on the bolts. As that was three years back and it's been fine, I didn't bother with any either. I did however use spring washers on the bolts, but that's just me being paranoid.
For those of you who venture off tarmac, the original shafts are a bit thicker than the one piece ones, but that's not something I'm worried about.
The offside shaft had more play than the nearside, but both had some, so I'm pleased to have got rid of that.
Post #769121 18th Apr 2019 3:59pm
donmacn
LR90XS2011 wrote:
there is a risk of snapping the bolts on removal, they are loctited in so go steady removing them, start with a breaker bar rather than an impact gun.
These are wise, wise words.... and I wish I'd read through this whole thread again before tackling the job. Crying or Very sad Crying or Very sad
4 came out fine; one snapped. You can be sure that I used a breaker bar on the other side.
I tried drilling the broken bolt, and putting a 'remover' into it. No joy. In normal circumstances I think I would have managed, but I think there's still so much threadlock in there that it's just not shifting.
I'm only really posting this to highlight and emphasis the point about the breaker bar rather than the impact gun.
Now I'm left with the hassle of having to get a new hub. The only saving grace is that I was going to be changing the rear discs anyway, so just a case of taking that forward a little. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #818947 9th Mar 2020 9:03pm
LR90XS2011
Bad Luck I feel for you DEFENDER 90 TDCI XS,
Post #818955 9th Mar 2020 10:02pm
Co1
Have one snapped off in mine. Will sort it this weekend but it hasn’t been an issue for about 18months!
Post #818957 9th Mar 2020 10:19pm
Those bolts snapping during removal is the most concerning part doing the job.
When I did mine I done them all by hand so you could feel everything, just the point of cracking them loose is the part to go most easy with.
Just taking your time is the way to go by hand. Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #818960 9th Mar 2020 10:33pm
donmacn
!! I did actually wonder how I might get on with just 4. If I was really pushed to use the car, I would have wondered more seriously. As it is I have most of the parts handy, I'll be away with work for a couple of days anyway, and the rest of the stuff will be here before the weekend. Donald
in the past..
Post #818965 9th Mar 2020 10:56pm
Grenadier
I’m about to do mine. Do most people replace the bolts or use the old ones if still serviceable? Keen to get this right. Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #818979 10th Mar 2020 9:18am
donmacn
I don't know about most, but I've decided to follow the example of ordering cap bolts and spring washers.
If nothing else, it saves me having to clean the old threadlock from the original ones.
Grand total of £10-odd from that link posted by LandRoverAnorak. Donald
in the past..
Post #818980 10th Mar 2020 9:27am
Grenadier
^^^ Thanks Donmacn. Monsieur Le Grenadier
Post #818981 10th Mar 2020 9:32am
Some people do re-use the bolts but it's not really recommended. For the relatively small cost involved, it seems like an unnecessary risk to me. Darren
Post #818982 10th Mar 2020 9:33am
Use socket head caps with spring washers and no thread locker. You'll never have problems again.
There's no real risk in normal use running with 4 not 5 bolts.
If you use gasket goo instead of or as well as the paper gasket you must be extremely careful not to let any get in the holes. More bolts shear in my experience because of this than because of thread locker.
Sheared bolts can be drilled out carefully but it's best to use a left hand helix drill bit. You'll usually find that once enough heat has been generated the stub unscrews.
Post #818996 10th Mar 2020 10:36am
^^^^ +1.
When I did mine I used proper paper gaskets with a light smearing of grease over the gaskets taking care not to plug up the thread holes in any way. Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #819030 10th Mar 2020 3:05pm
htb2
Must have been lucky.
Never changed the bolts over the last 35 yrs nor broke a bolt.
Post #819048 10th Mar 2020 6:37pm
Oldowner
If you do your own maintenance then you probably won’t break any halfshaft bolts. They normally snap because in the past they have been over tightened and stretched by garages / dealers using impact wrenches when changing brake discs.
I have owned 30-40 defenders and disco 1s over the years and most of them have had stretched halfshaft bolts when removed - I always change them for new.
Post #819065 10th Mar 2020 9:13pm
