![]() | Home > Maintenance & Modifications > Rear Half Shaft Replacement |
Nitroneil Member Since: 05 Mar 2019 Location: Stirling Posts: 132 ![]() ![]() |
Just fitted new shafts and drive flanges tonight, along with new pads all round. Took longer to get the front wheels off than it did to replace the rear shafts! Ended up loosening up the front wheel nuts and driving in and out driveway until they loosened. Like a different car now, old flanges were shot. (Just bought the car, have a long list
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1905 ![]() ![]() |
These are wise, wise words.... and I wish I'd read through this whole thread again before tackling the job. ![]() ![]() 4 came out fine; one snapped. You can be sure that I used a breaker bar on the other side. I tried drilling the broken bolt, and putting a 'remover' into it. No joy. In normal circumstances I think I would have managed, but I think there's still so much threadlock in there that it's just not shifting. I'm only really posting this to highlight and emphasis the point about the breaker bar rather than the impact gun. Now I'm left with the hassle of having to get a new hub. The only saving grace is that I was going to be changing the rear discs anyway, so just a case of taking that forward a little. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674 ![]() ![]() ![]() |
Bad Luck I feel for you DEFENDER 90 TDCI XS,
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3746 ![]() ![]() ![]() |
Have one snapped off in mine. Will sort it this weekend but it hasn’t been an issue for about 18months! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939 ![]() ![]() |
Those bolts snapping during removal is the most concerning part doing the job.
When I did mine I done them all by hand so you could feel everything, just the point of cracking them loose is the part to go most easy with. Just taking your time is the way to go by hand. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
!! I did actually wonder how I might get on with just 4. If I was really pushed to use the car, I would have wondered more seriously. As it is I have most of the parts handy, I'll be away with work for a couple of days anyway, and the rest of the stuff will be here before the weekend. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
I’m about to do mine. Do most people replace the bolts or use the old ones if still serviceable? Keen to get this right. Monsieur Le Grenadier
I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
I don't know about most, but I've decided to follow the example of ordering cap bolts and spring washers.
If nothing else, it saves me having to clean the old threadlock from the original ones. Grand total of £10-odd from that link posted by LandRoverAnorak. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
^^^ Thanks Donmacn. Monsieur Le Grenadier
Some people do re-use the bolts but it's not really recommended. For the relatively small cost involved, it seems like an unnecessary risk to me. Darren
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17911 ![]() ![]() ![]() |
Use socket head caps with spring washers and no thread locker. You'll never have problems again.
There's no real risk in normal use running with 4 not 5 bolts. If you use gasket goo instead of or as well as the paper gasket you must be extremely careful not to let any get in the holes. More bolts shear in my experience because of this than because of thread locker. Sheared bolts can be drilled out carefully but it's best to use a left hand helix drill bit. You'll usually find that once enough heat has been generated the stub unscrews. |
^^^^ +1.
When I did mine I used proper paper gaskets with a light smearing of grease over the gaskets taking care not to plug up the thread holes in any way. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 548 ![]() ![]() |
Must have been lucky.
Never changed the bolts over the last 35 yrs nor broke a bolt. |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 677 ![]() ![]() ![]() |
If you do your own maintenance then you probably won’t break any halfshaft bolts. They normally snap because in the past they have been over tightened and stretched by garages / dealers using impact wrenches when changing brake discs.
I have owned 30-40 defenders and disco 1s over the years and most of them have had stretched halfshaft bolts when removed - I always change them for new. |
