Home > General & Technical (L663) > 2020 Defender main discussion thread
This topic is locked: you cannot edit posts or make replies.  Down to end
Page 112 of 351 <123 ... 111112113 ... 349350351>
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Rolling with laughter Rolling with laughter Rolling with laughter Nailed the demographic Whistle Just because you're offended doesn't mean you're right.
Post #793036 14th Sep 2019 6:41pm
DAZ110
Will those wheels fit on my classic Defender? 😉
Post #793039 14th Sep 2019 7:03pm
Grenadier
Interesting
So it is actually a Discovery....🤔
https://jalopnik.com/what-i-found-when-i-c...1838080009 Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #793042 14th Sep 2019 7:37pm
Zed
There is a reason they are both made in Slovakia.
Nice to see they are honouring the original by using stuff from the old parts bin though.
That fabric sheet stuff underneath doesn't look like it will last 5 minutes.
Post #793043 14th Sep 2019 7:56pm
Tim in Scotland
Various companies made replacement alloy bashplates for Freelander1 and L320 RRS as I bought them but LR took the hump and unless you had one with a flap in it to access the oil filter and sump drain plug they charged an extra hour’s labour at service time......... i’m Sure it won’t take long for the accessory companies to get into production with a solid plate version for New Defender
The other problem with the OEM ‘plates’ was that they trapped mud badly and engine heat would dry it out to concrete making it very difficult to get out, also made backwards recovery from deep mud fraught as the under-tray acted like a scrapper. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #793055 14th Sep 2019 8:45pm
ids wrote:
https://jalopnik.com/what-i-found-when-i-crawled-under-the-2020-land-rover-d-1838080009
Good article about the underneath....... Some valid points esp about diff protection
Excellent article ~ author has done some legwork for once and not just quoting from the media pack given them by JLR. Thumbs Up
A bit worried about the coconut matting nailed to the underside. Taking sustainability just too far.
Post #793060 14th Sep 2019 9:41pm
The other problem with the OEM ‘plates’ was that they trapped mud badly and engine heat would dry it out to concrete making it very difficult to get Ultra-high-molecular-weight polyethylene (UHMWPE, UHMW)out, also made backwards recovery from deep mud fraught as the under-tray acted like a scrapper.
In other 4x4 areas they appear to have moved on to Ultra-high-molecular-weight polyethylene (UHMWPE, UHMW) with interesting results.
Post #793064 14th Sep 2019 10:09pm
RRUK
Fellrunner wrote:
RRUK - how did the quality of the materials feel to you? I do want to like this car ...
It felt extremely solid. The materials felt tough but luxuriously styled. The steering wheel felt chunky in the hand and controls were easy to hand.
Next step is to drive it! 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #793069 14th Sep 2019 10:22pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
I've been desperately trying to think where I've seen the steel wheels before. Now I've remembered:
https://www.rmtoys.co.uk/products/revell-1...gt-e-white
Post #793085 15th Sep 2019 7:33am
AndrewS
The matting materials used for inner wheelarch lining on the D5 is the worst idea ever. Mud, slush and ice sticks to it. Last winter I thought the wheel bearings had gone, upon inspection it turned out that slush/ice had built up between the wheel and inner lining. I then drove to a safe place to remove it. When I turned into a layby there was a nasty crunch noise. Turns out with the front wheels on full lock the tyre hit the now frozen solid ice. Resulting in a ripped off mud flap, lower trim and damage to the wing Big Cry 130's have feeling's as well you know Smile
Post #793094 15th Sep 2019 8:34am
I wonder how durable the plastics will be.
When I look at my '02 Disco2 and '07 Defender, every single bit of unpainted external plastic is now a random wishy washy grey colour, presumably due to UV damage. On the Disco, the wheel arch trims, rather than their original smooth textured finish, now are as rough as coarse sandpaper for the same reason.
There is an awful lot of external plastic on the new vehicle. I hope it is better.
Post #793110 15th Sep 2019 9:49am
Zed
From the other thread.
buckers19 wrote:
Seen the new defender 90 at the Goodwood Revival. Very plasticky and I managed to break the wheel arch by prodding it. For some reason it had plastic chequer plate in the wing mirrors.
https://www.defender2.net/forum/topic69242.html
Post #793116 15th Sep 2019 10:16am
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
As others have said the new Defender really should have been the new Discovery. I had a D3 for 8 years with very little in the way of problems, I am therefore beginning to think that buying a D3 with good provenance for a third of the price would make more sense as I’m sure the D3 will do exactly the same as what the new Defender will do without the fake checker plate etc and without the huge depreciation. My D3 was supremely comfortable, was superb in the mud and snow and would with the rear seats down carry a huge load and tow anything I needed to. I also think that the D3/4 will eventually become an iconic shape much like our proper Defenders.
Post #793129 15th Sep 2019 1:07pm
jaygti
United Kingdom 2002 Defender 90 Td5 HT Epsom Green
Yes I’m also interested in a D3/4. They look great, they’re cheap (maybe for a reason) and their versatile. Just need to budget for maintenance 🤔
Keep it for 3 years and then trade it in for a new shape 110 perhaps👍🏻 2002 td5 90 county hardtop
Post #793130 15th Sep 2019 1:29pm
NoDo$h
You need deep pockets to run a D3/D4. That, and a love for gambling.
They can be cheap to buy (although some people really do have inflated ideas of the value of *their* vehicle) but they are never cheap to run. You'll need to replace suspension bushes fairly regularly and the transmission needs to have been looked after (not a service item according to JLR, but then once out of warranty it's your problem Whistle )
They're essentially now in the space the P38 filled a few years back. On their 4th owner, maintenance is being skimped, bits are wearing out and the bills are mounting. Bangernomics they are not.
54 Freelander modded for mud
2008 D3 SE
2010 90 XS SW
1978 88 Series 3 undergoing surgery with a new owner
2007 90 County Truck Cab - gone
2006 D3 SE - gone
2004 Freelander Sport - gay
1999 Disco V8 ES rotted to bits
Post #793134 15th Sep 2019 2:25pm
This topic is locked: you cannot edit posts or make replies.  Back to top
