Home > General & Technical (L663) > 2020 Defender main discussion thread
This topic is locked: you cannot edit posts or make replies.  Down to end
Page 50 of 351 <123 ... 495051 ... 349350351>
RRUK
I’m sure I can’t say anything not already mentioned but I’ve said before (and printed in LRO) that the old Defender was way out of date and I know for a fact that JLR has not designed and built the L663 for the traditionalists, the purists or the laggards. It is most certainly going to cash in on the whole heritage factor.
Those people were never likely to buy the new Defender, JLR is tapping a new market sector and we should all get behind them and support it, it’s success means the continuation of the brand and the company, jobs for many people, home and abroad.
For those who can only see themselves driving the old Defender, well there will be loads around for many years to come at all price points. I’ve just got back into the Defender game for very little money myself, I have a great D3 for comfort plus workhorse stuff and a Range Rover Sport as a daily driver. That’s the diversity of the brand right there. New Defender will augment this.
Will I like the new Defender. Definitely. Will I buy one at some point? Maybe. Let’s see. 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #785539 7th Aug 2019 7:32pm
Santorini
United Kingdom 2015 Defender 90 Puma 2.2 SW Santorini Black
I saw a camouflaged one today near me in Shropshire. Is the release date imminent?
It was a nice surprise after only seeing images and videos online.
Post #785584 7th Aug 2019 9:08pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
spudfan wrote:
Inigo says
"My Discovery 4's new front suspension arms needed new bushes after just three or four days driving on bumpy gravel tracks through the Pyrenees. The Defender's live axles and coil springs have taken substantially more of a beating, over a longer extended period and not needed replacement yet. Although the ride on the motorway is not as smooth."
Thumbs Up That about sums it up for me...and no manual gearbox option.
The fact that you can hammer the independent systems harder without occupant discomfort is certainly not good for the mechanical health of the vehicle in the longer term. If you abuse live axles you get it back, with the independent systems they are inherently weaker anyway, and can be abused by drivers who either don't realise or don't care. There's a lot of knock-kneed Discovery 3/4 about these days, where the rear suspension geometry is completely shagged. The same applies to all independent suspension systems - Shoguns and the front end of many of the pickups suffer in the same way. The difference is that with a live axle you can change the bushes and get it pretty much back to factory spec with fairly basic tools, while sorting out an independent suspension system that is all to hell is rather more involved! ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #785598 7th Aug 2019 9:38pm
blackrangie
Australia
LRO article talks about:
Permanent All wheel drive
3 diff locks
D7u based.
Standard low range
18-22s
All terrains standard
Wading depth more than d5's 900mm
Coil & air options
Diff ratios different to D5
Paddle shifters optional
No manual
Trademark Alpine windows
110 more comfortable, 90 better offroad due to ramp over.
Tested to a level between other fullsize LR's and mil spec.
Stronger welded and braced subframes, balljoints, susp arms longer and stiffer.
Structural undertrays stiffer.
Large objective gains both on and offroad at this stage, without losing core defender DNA.
Adaptive dampners
Download full article on thier app, worth the read
Post #785630 7th Aug 2019 11:48pm
blackrangie
Australia
This is very interesting from the topgear article
LRO also talks about it being testing to a level between the current fullsize LRs and mil spec Cool
Post #785631 7th Aug 2019 11:53pm
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
I struggled to find a competent local garage to carry out 4 wheel alignment on the disco (they tried but gave up the last time I took it to them) the local LR Dealer couldn't help either.
All these modern systems are great as long as they are supported. I have to take my current D4 on a 80 mile round trip to get it serviced and returned in no worse condition than I left it (local jaguar and land rover dealers owned by same company and both stunningly incompetent).
On the basis of the most recent press I'm actually now looking forward to the new defender and will almost certainly get one (after teething issues have been solved by customers). Factory lockers (like the wrangler), low range, 18" wheels, coil springs, sounds like they may have been listening to some of our bleating.
Post #785633 8th Aug 2019 12:24am
Zed
Cool
Translation: It's done a few more miles of testing than the Disco.
Post #785763 8th Aug 2019 8:06pm
DSC-off
Yep, sounds about right. Laughing
Post #785766 8th Aug 2019 8:34pm
Markez79
3 diff locks
D7u based.
Standard low range
18-22s
Coil & air options
No manual
Adaptive dampners
Sorry for a stupid question, but how does Terrain Response work if Coil springs are an option? I thought Terrain Response was linked to the air suspension on modern Lamd Rovers?
Thanks
M
Post #785804 8th Aug 2019 11:27pm
DSC-off
The terrain response won't control the suspension on the coil spring versions - maybe adaptive dampers, if fitted.
In the same way Freelanders and Evoques have terrain response, but no air suspension.
Throttle response, braking, traction control and gear change can still be set up for different conditions.
Post #785806 8th Aug 2019 11:38pm
blackrangie
Australia
With the testing, according to the latrst articles and testing they had to rejig some of the test tracks and also use the hardest tracks at Estnor as it was breezing through everything. As an example given they use 2 inch concrete sets rather than the usual 1. Shocked
Kerb strikes, bridge jumps and pothole breaks. Not just testing of the wheels and suspension but knock-on effects such as the loads on the engine mounts.
Thats all that data is fed into the 6DOF rig and repeated for 8 weeks straight around the clock, simulating 10years extreme use, target is no failures after a strip down. Articles say that was acheived.
Post #785807 8th Aug 2019 11:53pm
DSC-off
Well, if the Freelander and Evoque can tackle the easier tracks at Eastnor, they are hardly going to stretch the capabilities of something with longer suspension travel, bigger wheels and low range gearing.
I'd expect them to be using harder test tracks!
Sometimes it's best not to believe everything you read.
Who is ever going to say that a new vehicle isn't as good as the old one, or the competition?
The only thing that is certain from the statements is the new vehicle is not upto military standards.
That would be an unrealistic expectation anyway.
Post #785808 9th Aug 2019 12:13am
blackrangie
Australia
Multiple articles have been very specific 4 or 5 last time i checked, do you really think LR is going to tell porkies to all the majpr car mags and put everyones expectations up, just to be let down.
The upgrades over the currentl fullsize LR's are very specific and fit inline with the increased test regime.
Subframes have had extra welding snd bracing to prevent cracking and give extra strength.
Bushes and balljoints for the susp control arms are more durable.
Front lower control arms longer and stiffer.
Structural undertrays are stiffer aswell.
Its also mentioned its been benchmarked against the "best 4x4s" around the world. Different 4x4s are the best in different countries.
JLR are on record in earlier articles saying its been tested against the competition and its exceptional or something similar.
LRO also points out the wading will be greater that a D5 which is 900mm!
JLR are usually best in class with most stuff so i dont have any reason to no believe these statements looking at things from a glass half full kinda way.
Only a few more weeks until we see. 😎
Post #785810 9th Aug 2019 12:29am
DSC-off
...do you really think LR is going to tell porkies to all the majpr car mags and put everyones expectations up, just to be let down.
Do you really think everything that is released to the press hasn't been passed by the PR and Marketing people?
Everything will be exactly what they want to get out, with a positive spin put on it.
Nothing that they don't want you know about will be publicised.
That's the way car launches work.
Benchmarking, ALL vehicles are benchmarked against the competition. Fact.
Pothole brake tests, kerb strikes, ALL vehicles from a Ford Fiesta up are tested for these events.
It's all spin.
"If you really hammer a Discovery the subframe cracks, the suspension arms break and the balljoints and bushes wear out"
That doesn't sound so good.
Post #785811 9th Aug 2019 12:52am
spudfan
Ireland
One AM. I think it is time we hit the sack. People will get the idea that us Defender owners are weird if we keep this up. As if having a liking for beam axles, separate chassis, a good selection of tools is not reason enough. Lets all resume in a couple of hours and it'll give the uninitiated the impression that we are normal....well sort of. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #785812 9th Aug 2019 1:06am
This topic is locked: you cannot edit posts or make replies.  Back to top
