![]() | Home > Maintenance & Modifications > Corrosion Prevention Guide! |
| Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4808
Always very informative postings thanks for sharing the knowledge. 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817
Zag, while my truck is very well looked after here, and while I don’t really like the idea of driving on the wrong side of the road Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
| Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026
Yes stone chip under rear wheel arch and other high abrasion areas such as axles if you go off-road. You will need about 12 aerosols (presume you are wanting aerosols) of 4941 for a 110 minimum. I charge £490 but to DIY budget for about £180 these days with ACF-50 BUT you do need a professional mask £80, plus filters £20. DO NOT breath in the acid convertor, it is lethal let alone the other products. You will damage your lungs permanently, ask me how I know!! Even with pro filters it gets through
This site gives an idea of price of kits. Rejel.com |
| boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 751
Thanks. I was planning to use POR15 Metal Prep that I already have in a hand pumped bottle rather than the aerosol acid converter. Am I safe to assume they are basically the same thing?
Yes, they are
Great thanks. Appreciate your advice.
Thanks for all your help and advice Zag. Got the underside treated this weekend.
Click image to enlarge Click image to enlarge Click image to enlarge It’s one hell of a mucky job but pleased how it turned out. Now just need to protect the rest. |
That’s tidy work boxoftricks
| NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 291
For those who wish to follows Zagato's pistol grip style pressure washer lance arrangement, mines just arrived from kranzle Aquaspray, part numbers as follows: - Stub Lance 12391, M22 Gun 12491
Link to website: - https://kranzle-pressure-washers.co.uk/ NormanD WE191 2015 110 XS Utility 2014 VW Caravelle 180 Executive |
Looks a nice job |
| Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 921
May I add another vote for Kranzle pressure washers. I've had a K1152 TST for five years and although it was expensive, it's been out of this world compared to my previous DIY store ones.
If you're REALLY keen, after you've washed all the muck off, you'll want one of these too: https://www.cardryers.co.uk/Master-Blaster-Car-Dryer.php They're absolutely fantastic. Just don't give it a whirl in your living room when you unpack it though.... |
| Def2WazzaMan Member Since: 17 Jul 2019 Location: Aberdeen Posts: 1
Thanks for this guide. I've been looking into Dinitrol products online. I have some rust evident around the wheel arches and noticed they produce a rust converter spray called RC 900. Does this spray work and stop any further corrosion or is it best to viist a professional body shop? https://www.tiltrak.com/product/dinitrol-rc900-rust-converter/
Thanks, high praise from a Pro |
| Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 628
I received my kit from Rejel yesterday. I’m looking at treating on Tuesday while the weather is hot and it will all flow well.
I’m looking at removing bumper grill headlamp surrounds and mud flaps and brackets for access. Are there any other items I should remove (110 usw). Do the plastic trays under seats need removing? I have also seen a dinitrol guide that suggest some holes should be drilled the plugged. Is this correct. If so does anybody have a copy of the guide available. Can’t wait to get stuck into this as the lack of treatment currently really lets my truck down |
| All times are GMT |
