![]() | Home > Technical > THE webasto Thread |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6670 ![]() ![]() ![]() |
It's the Webasto Thermo Test software but I'm not 100% happy now so I'll hold off on the how-to ![]() ![]() ![]() |
https://www.ebay.co.uk/itm/Analog-to-W-bus...2776404068 I've not used one myself but guys on DISCO3 have. ![]() ![]() |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Ideal thanks Martin
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
isacs Member Since: 28 Aug 2015 Location: Leamington spa Posts: 404 ![]() ![]() |
so I've fitted a cab heater which is just connected to my battery, question is do i need to fit an additional leisure battery?
Greg |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 ![]() ![]() ![]() |
Depends on how long you plan to run it for? If you're thinking of running it constantly during the night as the outside temps are -20 outside, then i'd probably consider it.
If it's a back up to the standard heater and you're not going to run it for long periods ( think 5-6 hours ) without the engine running, then i reckon you'll be just fine ![]() |
It’s when I leave it in the feilds, so only for 30mins to 2hrs. I might try it for long sessions on the drive. So if it won’t fire the engine after at least I’m not stranded
You should be fine, but a test is a good idea
![]() The main draw is on fire up, once the unit hits temp ( about a minute ) then the power draw drops drastically. Turning it on for a few minutes whilst the engine is running wouldn’t be a bad idea |
TJH1985 Member Since: 22 Aug 2016 Location: Midlands Posts: 238 ![]() ![]() |
It was an ideal Oc outside this morning so I thought it would be an excellent time to catch some data around coolant temperature with the Webasto only - Here is a 30 minute warm up with the Defender set to max fans and hot first thing this morning.
Thermotop C wired in series just before the heater Matrix, so naturally, the heater output seems to be good enough to defrost etc. within minutes. ![]() Click image to enlarge |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2698 ![]() ![]() |
Trying to sort out a remote for my Airtop ST2000, I spoke to several people and even a Webasto technitian. They all said that the T91 kit would work. I can confirm that it doesn't, I've tried all variations so I've pulled the T91 kit out and now sourcing another option.
I was under the impression that the Thermocall was only for newer models? Has anyone found a cheaper version of remote control? 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
How is your AirTop normally switched on?
Which Telestart kit do you have? ![]() ![]() |
Martin, I only have the rheostat to turn it on. Which means trudging down the garden to turn it on. Would rather just sit in bed and turn it on.
Don't have a telestart kit, The T91 is an RF unit from what I gather. Which is now surplus to requirements so will appear for sale very soon 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
T91 is Telestart
![]() Got a photo of your T91 kit? ![]() ![]() |
Ah, my mistake. I'll get a photo shortly 110 D250 SE HT
Pics as promised
Label on control unit ![]() Click image to enlarge Remote ![]() Click image to enlarge General Box Pic ![]() Click image to enlarge Box label ![]() 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
