![]() | Home > Maintenance & Modifications > Corrosion Prevention Guide! |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304 ![]() ![]() ![]() |
![]() Click image to enlarge https://dinitrol.co.uk/?utm_source=Copy+of...dium=email SKIP https://www.defender2.net/forum/topic83242.html |
Leviathan Member Since: 24 Oct 2015 Location: Staffs Posts: 248 ![]() ![]() |
I squirt a touch of ACF50 in mine. Seems to do the trick.
Jimmoore Member Since: 26 Jul 2015 Location: Scotland Posts: 161 ![]() ![]() ![]() |
Thanks! Did it remove the rust altogether?
I am gonna go through this guide comprehensively and keep my Defender in tip top condition. |
It doesnt convert the rust like say Kurust does but seems to form a barrier/repellent to water and prevent it.
The difference between ACF50 and normal oil is that it seems to hang around. You can tell I'm an expert on rust prevention! ![]() Nick |
How did you direct the spray into each rivet? Can you spray like say, WD40? |
Avion8 Member Since: 26 Jan 2015 Location: Perth Posts: 281 ![]() ![]() ![]() |
I did mine with a little spray bottle, and for the hard to get at parts a small paint brush will work the ACF-50 into the area. I think in the UK you can get aerosol cans with the little red tube that will get the ACF-50 into the rivet holes. We can only get the 4ltr containers of the stuff here.
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 694 ![]() ![]() ![]() |
ACF50 I don't think will remove the rust stain.
I had rusty rivets like that changed under warranty. Suggest doing that then make sure you keep on top of the ACF50. |
Cool... I thought about steel wool but seeing it's in the Stealers I might as well get them to replace. And then ACF the rivets going forward from there.
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2037 ![]() ![]() |
Yep, in the UK you can buy it in an aerosol so a quick squirt and then mop up with a cloth after. 2016 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
N1FWD Member Since: 08 Aug 2014 Location: Dundee Posts: 14 ![]() ![]() ![]() |
To apply spots of ACF50 you can get these splendid disposable pipettes from amazon:
http://www.amazon.co.uk/dp/B009WQPXLE/ref=...AA8EDKDVGY They are brilliant and about a penny each |
When I replaced the triangle panels on mine I put new closed rivets in and then with a small brush (model painting brush) I painted the heads of the rivets with clear lacquer (auto paint 2pac type) about 4 coats and painted in the hole of the rivet and no more steaks...... Yet anyway
![]() My build thread http://www.defender2.net/forum/topic17615.html |
Martin 01 Member Since: 13 Feb 2012 Location: East Yorkshire Posts: 502 ![]() |
So my rear cross member is rusting.
What is best the best thing to treat the rust with prior to repainting the cross member ? |
A rust converter.
Then Dinitrol inside the cavity or paint on the outside 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
I will be using Dinitrol afterwards but wanted to know what rust inhibitors people have used.
Loads out there but wondered which one is best. |
