Home > Maintenance & Modifications > Corrosion Prevention Guide!
Page 19 of 89 <123 ... 181920 ... 878889>
Cadence
England 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
Contact
Hi, Is Zagato still doing this service?
Sent a PM, called the number shown on this page for Chris a couple of times - no answer, and left a voice message. No feedback yet
Is he away at the moment?
Post #414563 7th Apr 2015 8:35pm
Keep trying, he'll get back to you, March and April are always busy for the trade.
It'll be worth your patience and perseverance Thumbs Up
Post #414569 7th Apr 2015 8:39pm
Def90
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
Hi Cadence
He is around,I spoke to him yesterday morning on his home number.
Post #414684 8th Apr 2015 8:06am
Venomator
Re: Contact
He certainly is, I received a quote from him recently... Thumbs Up
Although he may take a while to respond to PMs as he is very busy... Mr. Green
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #414717 8th Apr 2015 9:47am
Cadence
Now in contact with Chris - thanks all
Post #414718 8th Apr 2015 9:53am
scotia
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
RECOMMENDATION REQUIRED? Need to know where to get your new Defender protected against corrosion? Quote from Bowler Motorsport Technician yesterday. "Your 110 is the best protected Defender we have ever seen in here - it will last forever!" All down to the thorough treatment it received from Zagato (Chris) last month.
Post #416080 14th Apr 2015 8:22am
Cadence
Booked in with Chris a couple of days after the end of May delivery ETA.
Getting excited already!
Post #416083 14th Apr 2015 8:38am
Zagato
Nice to have my work acknowledged especially by Bowler, thanks Jo Thumbs Up
My next two Defenders are re-doing undersealing work done by two different companies Rolling Eyes plus all the extra stuff I do to the body and chassis which is the important bit as these things rot in critical areas from the inside out.
A simple ad-hoc splurge of underseal is pretty useless, you really have to get your smaller nozzles into all the hidden areas that are not so easy to get at. Plastering the outside of the chassis with gunk may look like a done job but it's the inner areas which collect mud/dirt that rot and there is a lot of them.
I am hoping to produce a more thorough guide to the one I have on hear so that people can see exacktly what needs to be done and what extent the work involves so that it's easier for others to do there own Defenders and saves me time in the evenings explaining to folks that call as it's difficult to describe certain areas/brackets etc. Always happy to help where I can though Thumbs Up
Post #418420 23rd Apr 2015 4:48pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
I did a bit of paint protection at the weekend.
Previously my door seals had rubbed through the paint at the bottom of all the door frame and caused corrosion. This was fixed under warranty and they had applied some waxoil type stuff to stop it happening again.
I noticed that the paint was starting to scuff again so I used some 3M Helicopter tape left over from my bike between the paint and the door seal. I also put some on the edge of the sills and the bit just inside the sills to prevent the paint getting scuffed from feet.
Hopefully this will mean I won't have to go down the checker plate route eventually for the sills.
Hopefully you can see on the pictures
Post #418560 24th Apr 2015 8:17am
Mr Fox
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
I've PMd Zagato for a quote on a new 90 SW, however, in the interim, I did have two question for the knowledgeable.
I assume it would make sense to replace all the hardware with stainless bolts before doing the corrosion protection - am I wrong? Furthermore, would it make the most sense to replace them whilst carrying out the protection?
Secondly, would the same carry over to a the fitting of the spare wheel carrier?
I'd like to give the beast the best start in life and would rather have the job done once and done right.
Post #421748 7th May 2015 9:47am
X4SKP
To add to the advice so far...
 SKIP
Post #422072 8th May 2015 5:40pm
MOve
England 2015 Defender 110 Puma 2.2 CSW Keswick Green
Excellent. Thanks for posting.
Post #422411 10th May 2015 5:03pm
jonnyboy
United Kingdom 2005 Defender 90 Td5 XS CSW Tonga Green
Chris (Zegato) did the houours on my 10 year old TD5 last week and did a cracking job. Really thorough!
Highly recommended
Post #422929 12th May 2015 4:43pm
Mynstral
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
Hi All. Chris worked his magic on my Utility yesterday. Very pleased with the results. Thumbs Up Bow down
Regards Myn. Smoke me a kipper I'll be back for breakfast.
Post #424158 17th May 2015 2:27pm
Steve W
Having had the underbody done by the dealer as part of the deal, there is only one check that needed doing.......a trip to Zagato (Chris) to ensure all was good, sadly as Chris has previously posted mine was one of the defenders that he was doing the job on as the best way to discribe what he checked was laughable Laughing
Couple of days later, job done top man,top job attention to detail out of this world. Cannot recommend highly enough. Bow down
Post #424182 17th May 2015 4:23pm
