Home > Maintenance & Modifications > Corrosion Prevention Guide!
Page 11 of 89 <123 ... 101112 ... 878889>
lukev01
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
10% off any Dinitrol product. I have copied the text below, from the email I got today.
You're invited to visit Dinitrol stand 1-29 at the Practical Classics Car Restoration Show at the NEC in Birmingham on the 12th to 13th April 2014.
The Practical Classics Car Restoration Show will offer inspirational restoration advice, demonstrations, hands on experience and must-have products to restore a classic car.
If you are restoring a classic car, want to learn more about keeping them on the road, are looking to appoint a professional restorer or simply love classic cars then this is the show to attend.
Click on the link below to register to receive the latest news and updates regarding this event. By registering you will also qualify for a 10% discount on any Dinitrol product ordered from our e-commerce website, www.rejel.com
Hyperlink won't copy across but I think you can get to the same point via the website above. 1970 Series 2A 88"
Post #321120 2nd Apr 2014 8:49pm
JMG
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Stornoway Grey
Can anyone get me any contact details please
Can anyone get me any contact details please .
Post #324071 16th Apr 2014 12:53pm
funrover
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Quick question, this was alluded to but not sure if it was Windscreen sealant or Sikaflex pushed into panel gaps? Editor of FunRover - One blog. Read it!
Land Rover rebuild video series here:
Post #325311 22nd Apr 2014 3:07pm
Andy RV
I've had a bit of a Dinitrol learning curve this weekend!
1. Don't attempt to squirt the thick stuff through the extension nozzle, when it finally works its way through it uncontrollably pours out everywhere!
2. When spraying the ML turn the compressor pressure down, otherwise it bulges the can and pours out everywhere!
3. Don't kink the extension nozzle, again the can bulges and then it pours out everywhere!
At least my drive won't rust now.... Laughing
Post #328449 5th May 2014 7:40am
X4SKP
Hello Andy RV
I have been preparing to give my 90 the Dinitrol Treatment so would like to know a bit more.
1. What Dinitrol Products did you use (other than ML)?
The list can quickly grow, currently mine looks like this...
RC 900 for Cavities and Seams where a Rust Converter is needed.
ML Penetrating Primer for general Cavities and Seams.
3125 for all Internal Chassis Box Sections and Bodywork Cavities + a 'mist layer' for all External Surfaces.
445 for Wheel Arches (Stone Chip Protection).
4941 for general all over Final Coat.
2. Did you use each type of Dinitrol from a Schutz can?
I intend going down this route and will use a Schutz Gun and Compressor to apply,
if you did the same, was it difficult to get this working well?
3. Any photos... or was it just too messy?
DIY...NITROL
Thanks SKIP
Post #328868 6th May 2014 11:21pm
Andy RV
I bought this kit;
http://www.rejel.com/rejel-store/classic-kits/din01m.aspx
I used the ML3125 in the cavities and doors then 4941 on the chassis / underbody. I also bought a can of ACF-50 for the hinges and any other exposed metal work on the exterior.
Yes I used the supplied gun running from my little 25 litre compressor which kept up no problem.
When spraying the 4941 through the gun with the standard spray nozzle I ran the air at full pressure and it worked really well, it's got quite a concentrated spray into areas that you physically can't get into.
For the ML3125 I initially sprayed at full pressure, this caused the base of the can to bulge and emptied it in 3 'squirts', it pressurized the can so even when my finger was off the trigger it poured out of the nozzle.
After that I turned the air down and it sprayed on really well. You need to be careful not to kink the hose because as soon as you do the can pressurizes, then when the kink is released it will release the pressure in the form of ML squirting everywhere!
No photos but it looks ok! At the end of the day it's just thick black waxy gunge.
Post #329018 7th May 2014 3:32pm
Andy RV
Also ensure you have plenty of old rags for cleaning up with, I used petrol which worked well, thinners would work as well.
If you care about your drive put a tarpaulin down, do the cavity wax last it drips out.
To clean the gun out I filled one of the empty dinitrol cans with petrol then sprayed it through until it ran clear.
Post #329021 7th May 2014 3:36pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
I stuck duct tape over all the holes in the bottom of the chassis rails and cross members before I did my cavities. After a few days, you take it off and the dripping is much reduced. Just remember to clear the holes out again to allow water to escape later on.
Post #329042 7th May 2014 4:13pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Blimey, sounds like a flame thrower waiting to go off....got to be a candidate for the Darwin Awards.. Shocked
Simon
Post #329043 7th May 2014 4:16pm
Andy RV
Just don't spray near any sources of ignition, common sense.
Plenty of flammable liquids are sprayed everyday, paints, oils, de-greasers ect and I don't see that many people walking around on fire!..
Post #329070 7th May 2014 5:23pm
X4SKP
Thanks Andy RV that's useful.
Based on the principle of First Prepare...I have been cleaning mine thoroughly recently
trying to ensure all mud, oil and a recent diesel fuel leak (breather hose) are removed before
the Dinitrol goes on.
Did you remove the front wheel arch inner linings and rear light guard linings?
Even though mines just over 3 years old, and had an easy life, this cleaning scrutiny has proved
one thing, the poor quality of finishing of some of the aftermarket accessories fitted. I have removed
the side steps and NAS rear step for a full strip down and tougher refinishing. I think the standard LR
mud flap brackets are also destine for a rethink. SKIP
Post #329077 7th May 2014 5:56pm
Andy RV
No I didn't remove any of the linings, I removed all of the mud flaps and the entire tow bar assembly. Between the rear cross member and mud flaps struck me as an area likely to collect mud and moisture.
Mine is only 12 days old so cleaning was easy. Wink
Post #329082 7th May 2014 6:11pm
X4SKP
Thanks and good luck with your Defender. SKIP
Post #329087 7th May 2014 6:17pm
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
Hi Zagato,
You have a private message. 2003 Td5 110 Hardtop
Now a 2013 110 USW too.
Post #341723 30th Jun 2014 6:56am
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Please could anyone advise if it is worth the effort to give the chassis a coat of say chassis black paint (after treating any rust) and before dinitrol treatment?
Post #343394 7th Jul 2014 10:56am
