Home > Technical > THE webasto Thread |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
im gonna fit a rear heater in aswell..like this http://www.ebay.co.uk/itm/320971090016?ssP...1423.l2649 it'll keep thr rear warm, and it can run off the engine / webasto. i find the rear doesn't heat up very well at all even in our -10. |
4th Sep 2012 10:21pm |
Ok BIG day today.
Went and fought to get the fuel pump, and a part of the loom. Bodged up a loom and it fired! Took 2 attempts as the fuel pump needed priming and i'm struggling to keep up with the flow rate of the 22mm inlet. So i'll find a header tank,a central heating one and run it again. The webasto Z/C manuals wiring schematic was incorrect colour wise but it seems that they all share a common configuration as regards to the pins. i'll get a better water circuit and put a video up. costs so far......still less than a meal out for 2 |
7th Sep 2012 8:42pm |
so the webasto works. i have on another thread http://www.defender2.net/forum/topic14891.html found what i was looking for with the help of Dgargel and they are on order with relay holders and new pins.
so i now need to sort the loom out. Are the pins a standard type for these type of plugs or are they a webasto only thing? I have the original plugs along with my bodged up loom but a new one is in order. I have founds some Tees for £3 ea that will allow me to tap into the F&R to the heater and some hose. I 'll need to buy and exhaust, change the inlet to one with a filter and mount the unit. FYI, Also found this as a potential timer. i don't want or need one T BH but @ £9 its a cheap digital timer. http://www.ebay.co.uk/itm/221081628505?ssP...624wt_1344 Spend so far...less than a oner |
9th Sep 2012 1:16pm |
The bay help you
http://www.ebay.it/itm/2-PIN-POWER-PLUG-FO...003wt_1103 http://www.ebay.it/itm/WEBASTO-THERMO-TOP-...974wt_1103 http://www.ebay.it/itm/2-PIN-PLUG-FOR-EBER...931wt_1103 A lot of goodies here http://stores.ebay.it/WorldWideDieselHeate...4340.l2563 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
9th Sep 2012 1:35pm |
For the timer, I have this one
http://www.ebay.com/itm/110946658702?item=...mp;vxp=mtr plug http://www.ebay.it/itm/EBERSPACHER-WEBASTO...826wt_1103 cheeper with no alarm http://www.ebay.it/itm/Timer-Webasto-/2511...500wt_1351 Minitimer http://www.ebay.it/itm/EBERSPACHER-DIESEL-...863wt_1103 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
9th Sep 2012 1:37pm |
Testing the Z
http://youtu.be/rM9XccsDVPI i did 4 vids. there was 18 litres of water and it heated it in 10-15 minutes. |
10th Sep 2012 4:33pm |
Great service...relay here already!
Didn't buy from italy in the ends as the slapped a £30 delivery charge on for 2 relays got them off ebay. stripped the unit today. looking to mount the unit. How do you get the heater air supply bit out |
11th Sep 2012 6:59pm |
great video Marcus - you still have a fair way to go but £250 looks possible. have you serviced the unit yet ?
AFAIK the air inlet is just clipped onto the unit, you may want to buy an air filter housing for it or make something up.. maybe from a lawnmower ? have you decided where to mount it yet ? Daniele used an entreq kit that fits near the gearbox/xfer box x-member, probably worth having a look on the entreq site, I believe Bren may even have one in stock. |
11th Sep 2012 7:58pm |
i've strip it earlier steve. looks OK TBH.
i'm gonna try and fit up under the wing by the bulkhead. IRB / mobile centre fit them there i believe. easy for wiring and water pipes. waiting back for a price for the plugs so i can make a new loom. |
11th Sep 2012 9:37pm |
12th Sep 2012 8:40am |
Sorry Steve i meant the air intake off the 110! the big plasticy bit that feeds the heater. Also where would i tap into the 110 fan electrics. Theres a big black and orangy wire going into the fan motor. Also do you have a fitting kit parts number for a puma, ie the hoses / Tees supplied? |
12th Sep 2012 8:52am |
have a look at cobs documents, it's all in there, but yes, essentially the orange wire is where you need to enter the system. note the webasto wiring loom has a mass of wires but by far the most hd are the wires for the fan so make sure you use the same or higher rated.
the webasto loom has a relay, when not energised, the power flows through the orange wire as standard, when the relay is energised the power comes from the webasto, so you will still need to have the fan switched on to make the inside warm with the webasto also, note the way the heater switch/valve works on the truck |
12th Sep 2012 10:42am |
Many thanks. |
13th Sep 2012 8:42am |
Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582 |
Had my Thermo Top C professionally installed today, very pleased with the quality of the work and location of heater and exhaust run.
How are you planning to plumb in the pipe work to the original system ? 2007 TD5 90 Hard Top |
21st Sep 2012 11:39pm |
