![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
QuintusJM Member Since: 19 Apr 2025 Location: Johannesburg Posts: 3 ![]() ![]() |
I found most of using the chatgpt assistant created by one of the members: https://chatgpt.com/g/g-U7gyA4J3E-gap-iid-diagnostics-assistant and I also changed MultiCAN-742.
Here is everything I changed: EUCD-098 Lane Departure Warning: LDW Fitted & TSR Fitted with OverSpeed MultiCAN-498 LaneKeepAssistLKA: LKA fitted EUCD-026 Power Steering Type: Electric Power Steering with external angle and torque control, only for JLR MultiCAN-742 Traffic Sign Recognition TSR: TSR Fitted with OverSpeed |
crazyg Member Since: 25 Jun 2025 Location: Tel Aviv Posts: 4 ![]() ![]() |
Using the Gap G4 I tried to activate the ACC
all was enabled but the AEB error wasnt able to be cleared. this G4 unit was bought a year ago, could it be because its old firmware it didnt reset the DADC? Thanks |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 339 ![]() ![]() ![]() |
The AEB error following editing the CCF is generally due to the DADC not being updated/reset correctly.
Before editing you should always make sure the tool is updated to the latest firmware to minimise the possibility of errors. GAP support are generally helpful. Defender 110 D300 X-Dynamic HSE MY22 Defender 110 Station Wagon 2011 (gone) Defender 110 DCPU 2007 (gone) |
Thanks,
It worked! |
dgm130 Member Since: 21 Apr 2024 Location: SK Posts: 5 ![]() ![]() |
I tried the same and nothing changed. Is there another setting that needs to be switched perhaps? |
Manuto Member Since: 27 Jan 2021 Location: Vancouver Posts: 23 ![]() ![]() |
Have you tried it or found any else about it? |
Sticks999 Member Since: 10 Sep 2024 Location: Durham Posts: 8 ![]() ![]() |
Disable the fake engine noises played through the stereo (or choose different versions) with these two settings:
Next Generation Power Train Sound Quality (NGPTSQ) MultiCAN-584 NextGenPwrTrnSQ Select: Not Fitted MultiCAN-585 ActSndDesignPwrlvl Not Supported Select: Not Fitted * Both set to ' Not fitted ' for off |
Is a pivi reset required for this kind of change? My other changes didn't require a pivi reset. |
inith5 Member Since: 08 Apr 2023 Location: Bavaria Posts: 31 ![]() ![]() |
Replace battery service/test Gap IID
I can't find anything in the service/test menu where I can program a new one. My first battery was replaced under warranty after almost two years because it only had half its capacity. I hope the new battery lasts longer this time. But if it happens again, my warranty will probably be void, and I'll want to replace the battery myself. Regards [/b] 23.5MY Defender 110 D250 HSE |
DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 280 ![]() ![]() |
Request a firmware update from gap with service options on it. They seem to be able to do that if requested MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
