Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 111 of 112 <123 ... 110111112>
QuintusJM
South Africa
I found most of using the chatgpt assistant created by one of the members: https://chatgpt.com/g/g-U7gyA4J3E-gap-iid-diagnostics-assistant and I also changed MultiCAN-742.
Here is everything I changed:
EUCD-098 Lane Departure Warning: LDW Fitted & TSR Fitted with OverSpeed
MultiCAN-498 LaneKeepAssistLKA: LKA fitted
EUCD-026 Power Steering Type: Electric Power Steering with external angle and torque control, only for JLR
MultiCAN-742 Traffic Sign Recognition TSR: TSR Fitted with OverSpeed
Post #1067168 6th May 2025 7:06pm
new110P400
Canada
Hi guys,
I think I found the fix for the honk to not  honk on double lock:
Multican-742 Second Press Warning Chirp
Standard: Enabled
Change to: Disabled
Post #1070088 20th Jun 2025 10:29pm
crazyg
Israel
Using the Gap G4 I tried to activate the ACC
all was enabled but the AEB error wasnt able to be cleared.
this G4 unit was bought a year ago, could it be because its old firmware it didnt reset the DADC?
Thanks
Post #1071355 13th Jul 2025 6:13pm
Fifth Horseman
The AEB error following editing the CCF is generally due to the DADC not being updated/reset correctly.
Before editing you should always make sure the tool is updated to the latest firmware to minimise the possibility of errors.
GAP support are generally helpful. Defender 110 D300 X-Dynamic HSE MY22
Defender 110 Station Wagon 2011 (gone)
Defender 110 DCPU 2007 (gone)
Post #1071365 13th Jul 2025 6:46pm
crazyg
Israel
Thanks,
It worked!
Post #1071617 17th Jul 2025 8:09am
dgm130
Canada
DefenderMidlands wrote:
Configurable Terrain Response
MultiCAN-736 Config TR Fitment - Not Configured > change to Off Road Configuration
MultiCAN-755 Config TR Mode - Not available for selection > Change to Available for selection with timeout
I was able to successfully select with the rotary after I changed the following:
MultiCAN-797 Ter CT Select In FCPB
- Changed to > "Rotary used for selection within touch
I tried the same and nothing changed. Is there another setting that needs to be switched perhaps?
Post #1072037 23rd Jul 2025 7:26am
Manuto
Canada
jlrogers wrote:
Anyone played around with turning off Engine Noise Cancel? My Defender arrives in a couple of weeks and hoping to start upgrading the sound system. Hoping to be able to turn off the Engine Noice Cancel and/or Active Noise Cancel (can't find any reference to ANC in CCF files)
MultiCAN-683 EngineNoiseCancel
Not Supported
Have you tried it or found any else about it?
Post #1072882 6th Aug 2025 8:09am
Sticks999
Disable the fake engine noises played through the stereo (or choose different versions) with these two settings:
Next Generation Power Train Sound Quality (NGPTSQ)
MultiCAN-584 NextGenPwrTrnSQ
Select: Not Fitted
MultiCAN-585 ActSndDesignPwrlvl
Not Supported
Select: Not Fitted
* Both set to ' Not fitted ' for off
Post #1072885 6th Aug 2025 8:40am
dgm130
Canada
Is a pivi reset required for this kind of change? My other changes didn't require a pivi reset.
Post #1073735 20th Aug 2025 1:21am
inith5
Germany
Replace battery service/test Gap IID
I can't find anything in the service/test menu where I can program a new one.
My first battery was replaced under warranty after almost two years because it only had half its capacity.
I hope the new battery lasts longer this time. But if it happens again, my warranty will probably be void, and I'll want to replace the battery myself.
Regards
[/b] 23.5MY Defender 110 D250 HSE
Post #1073941 23rd Aug 2025 8:39am
DefenderMidlands
Request a firmware update from gap with service options on it. They seem to be able to do that if requested MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
Post #1073954 23rd Aug 2025 11:30am
PetarJ
Bulgaria
Re: Retrofit led premium US
mmbanf wrote:
HI ,
we are trying to solve a problem with retrofitting premium LED headlights on US specification vehicles,
User with defender equipped with premium LED headlights, can you please post a photo of the ecu configuration of headlights A and B?
Example in the photo.
Thanks in advance for sharing.
Marco
I have managed successfully to retrofit Matrix headlights in my NAS ( US/Canada) vehicle. No errors . Everything working as expected. Let me know if you need the list of the settings
Post #1074582 2nd Sep 2025 1:47pm
PetarJ
Bulgaria
mmbanf wrote:
HI ,
Marco
Post #1074583 2nd Sep 2025 1:47pm
Mukafuka
PetarJ wrote:
mmbanf wrote:
HI ,
Marco
Please send this info my way. Can you tell me what part numbers are required.
Post #1075134 9th Sep 2025 6:59pm
PetarJ
Bulgaria
Hi, I have retrofitted LR144293/L8B2-13W030-HG and LR14429/L8B2-13W029-HG.
Take a look at the other available options here :
https://docs.google.com/spreadsheets/d/e/2...-J/pubhtml
Post #1075141 9th Sep 2025 8:06pm
