![]() | Home > Puma (Tdci) > nasty whistle from turbo/manifold |
whip Member Since: 17 Sep 2010 Location: haute savoie, Alpes Posts: 18 ![]() ![]() ![]() |
hi andrews, i saw the intercooler hose, and there are no split.
there are soot exhaust, between the turbo and manifold, ![]() ![]() ![]() do you think, with the nakatanega TD4 turbo manifold joint , it will be ok ? http://nakatanenga-tours.de/shop/article_H...CHLDTD4%26 I have noticed a slight power loss and slight increase to consumption, it must come from the defective joint regards, nico Last edited by whip on 2nd Nov 2011 6:59pm. Edited 1 time in total |
We have solved this before by removing the turbo and having the flanges machined. QRZ 2e0vpf
Ooh yeah, we have replaced exhaust manifolds that have cracked too.
Here's a pic of the flange that you can see has trails of soot escaping, this is the flange we have machined, as well as the manifold side of the turbo. ![]() |
hi
you changed the exhaust manifold?? ![]() ![]() How much does it cost. Now with the new collector, you have no worries? You have put a stronger joint, or the original land rover joint? regards, nicolas |
We are at this very moment 'modifying' this very car and exhaust, I'll put pictures up when I've finished it. QRZ 2e0vpf
ah ok, I look forward to the final resulting output, with lot of photo
![]() good luck Ps: your defender are remap? |
