![]() | Home > My Defender > Lizzy |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3597 ![]() ![]() ![]() |
Thank you for your reply. Regarding soot load, I have used Car Scanner through a cheap wif ELM327. I could read my dpf load at 40%. I do not know how accurate that was.
But your solution is so much better, because I never want to go through the trouble of connecting my phone to the ELM327 for the sake of using a dashboard. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
steveww Member Since: 05 Jan 2022 Location: Malton Posts: 610 ![]() ![]() ![]() |
Changed the engine oil this afternoon. I've done this before on previous classic cars I've owned. One bonus with the Defender is I don't have to jack it up to get at the sump plug and filter. I was expecting the rush of oil when removing the sump plug, I caught all of it except one small dribble. I was not expecting deluge when removing the filter, which took at lot of effort to unscrew; fortunately I have a special tool for this. After refilling, it's very difficult to read the clear oil on the dip stick. So far 6.3 litres is on the centre.
I have discovered another essential tool for working on Defenders. Being of average height this comes in very handy. ![]() Click image to enlarge Work is progressing slowly on the ODB display. Real work is getting in the way. I'm waiting for a display and case to be delivered to finish the prototype. Stay tuned... |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11049 ![]() ![]() |
Yes that last tool helps alot
A great weekend camping in the Cotswolds.
Following on from https://www.defender2.net/forum/topic48682.html I decided to give it a go. I don't find my Defender too noisy apart from the rattle of the diesel. I purchased https://www.dodomat.com/collections/sound-...-pro-black and https://www.dodomat.com/collections/thermo...-liner-pro and set to work.
![]() Click image to enlarge Lots of cutting and sticking and the dead mat was installed. Next up I trimmed to acoustic liner to size and fitted it. ![]() Click image to enlarge As you can see I took the bonnet off the car and worked on the bench in my workshop. Much easier than trying to do everything upside-down. While I was in there I also added dead mat to the heater intake. When it's tapped it rings like a bell and it goes straight into the cabin. I wanted to do this on the bench too but an AC pipe gets in the way of removing it. However, I managed to work around this and completed the job with it in place. ![]() Click image to enlarge I did a test run this morning. The top of the AC pump and an AC hose rubs slightly. So the big question does it make a difference? Yes it does. While it's still not at Rolls Royce levels of refinement the engine noise has been reduce from a clatter to a rumble. I can't believe how much difference it makes given that it's outside the cabin. Of course I can now hear the tyre roar and transmission whine more clearly now. I'm just waiting for Wrights Off Road matting to do the rear of the cabin, it has factory fit front matting. |
To save the AC clutch cable I've routed it under the cowling.
andy2111 Member Since: 17 Oct 2021 Location: Kent Posts: 369 ![]() ![]() ![]() |
Thanks for the soundproofing info, I'm getting a bit obsessed with quieting mine which is a bit foolish considering it's a defender!
Have got the engine bay next on the list and had not considered the air con inlet.. So the list just got a bit longer! |
A quick, low cost and easy to do sound upgrade.
With Lizzy being not quite as noisy, I've done a quick tweak to the sound system. She has an Alpine CD head unit, I'll be swapping this out for a DAB unit later, with Rockford speakers and matching Alpine Sub. Rather than swap out the speakers, which I think are OK. I've done a little mod that I've used on others cars to good effect in the past. I purchased a couple sheets of https://uk.rs-online.com/web/p/acoustic-insulation/8814557 Other similar products are available, I have a trade account with RS. Each sheet was cut in half length ways. Each half was folded to 1/3 size. Remove the four screws holding in the speaker then stuff the folded padding into the speaker hole and give it a bit of a fluff. Replace the speaker. Good results. The damping of the space behind the speak sharpens up the sound. Ideally the panel that the speaker mounts into should be made stiffer but... It's a Defender. |
Now that I've improved the soundproofing with the bonnet, next up is the cabin. I did not want to go with the usual multiple layer system of damping pads, closed cell foam, rubber mat/carpet. My Defender is a regular dog taxi for my two Labradors. I want the ability to remove everything so I can clean out all the cr@p, dog hair and other random detritus. I decided to go with http://www.wrightoffroad.com they supply 8' x 4' sheets which can be cut to size as required. I will need 2 sheets to do what I want.
Last night I did the rear passenger foot well and the rear load area. I used the old thin rubber matting as a template and cut the new sheets with a Stanley knife with a new blade. It's tuff stuff requiring several passes with the knife to cut through. It's surprisingly heavy stuff. ![]() Click image to enlarge Next up is the wheel arches. I'll use the old thin matting to cut up for templates before cutting the rest of the matting. I'll post an update with the results. |
Would love to hear what difference this makes to noise levels and the booming sound that can come from the rear of the truck
I had to pop out and pick up some feed yesterday afternoon. The new matting has made a difference, not as big as doing the bonnet but it's definitely quieter now. There's a lot less transmission noise and a reduction in engine noise. The main noise now is tyre roar, I'll be doing the rear wheel arches soon which should cut that down quite a bit. Of course the penalty is that I can hear all the rattles now.
Note: In the rear load area on top of the mat I have a soft closed cell rubber mat about 10mm thick, then a cotton floor mat on top of that. My dogs need their comfort and the cotton mat traps a lot of water, remember I have Labradors; they love a swim or a muddy puddle. |
During the recent heatwave we had 38C here. I went into the garage last night to start making the templates for the soundproofing on the rear wheel arches. Unfortunately the high temperate has caused a tin of wood preserver to explode all over the front of Lizzy
![]() I've now got most of it off, I'm sure I'll be find little spots I've missed for many months to come. My wife had a very philosophical view, she said "On Tuesday evening somebody won £192M on the lottery, you had a tin of wood preserver explode on the Defender, other people lost everything in a wild fire and there's still a war in Europe". |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2461 ![]() ![]() |
Re reading the dipstick. See https://www.defender2.net/forum/topic79934...t=dipstick |
Even though it's summer and we have light evenings, I've fitted some new LED headlights to Lizzy. When I purchased her she already had LED headlights, the dip beam was not too bad but main beam was just a slightly brighter version of dip; there was not much distance to the beam. They were E marked but no branding on them, I'm guessing some Chinese clones from fleaBay.
I've now fitted Vision X Vortex units from TMD. https://tmdtuning.com/shop/defender-led-he...full-halo/ ![]() Click image to enlarge Much better beam pattern on dip with a wider spread than before. Main beam now has a proper range. Roll on those dark winter evenings. |
