Home > My Defender > Lizzy
Page 5 of 8 <12345678>
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
A new wiper relay is £10 or a gallon of diesel.
Post #970067 5th Nov 2022 8:18pm
It seems to be a little more if you have the variable delay (aka VW "99") relay. If you know of a source of those for a tenner, please say. Very Happy
Post #970074 5th Nov 2022 9:32pm
steveww
Following on from this thread
https://www.defender2.net/forum/topic67610.html
I eventually removed the little fan thingy.
It's an arse of a job to do and I lost most of the skin off my knuckles. I have just done my first long drive since its removal. My non scientific opinion is that the pick up from low RPM is better and overall the throttle response is smoother.
While wrestling with the air box I remove the fan shroud. It was cold in the workshop so I checked the resistance of the viscous fan coupling. It should be free at low temperatures. It turned quite freely but there was a slight binding at one point in its rotation. A good squirt of oil soon freed it up. It has reduced the engine noise in the cab so that's an extra bonus.
Post #972690 28th Nov 2022 11:16am
steveww
Just fitted an Alpine UTE 204DAB radio to replace the old Alpine unit. The new one is plug an play being the same make. The existing connection and microphone can be used. I added an extra wire for the display dimming function when the lights are on. I just picked up the illumination wire from the cigar lighter.
I also fitted the Nakatanenga DAB aerial https://www.nakatanenga.de/en/electrics/ap...FLEXANTDEF
The original telescopic aerial was a bit the worse for wear after navigation of some Devon lanes.
Very pleased with the result, I have set the display colour to green which matches in nicely with the other dials. I also now have access to many more radio stations.
Post #973213 2nd Dec 2022 4:28pm
chek
Switzerland 2016 Defender 90 Puma 2.2 SW Havana
That looks like a real upgrade, compared to my 133BT. On the one pictured it says 204, you write about model #205. Both exist: which one you got? Thanks!
Post #973243 2nd Dec 2022 7:52pm
steveww
Oops that’s my fat fingers. It’s the 204 I fitted.
Post #973249 2nd Dec 2022 8:24pm
steveww
I purchased a set of Dirt Defenders a while ago and had them sprayed to match my Defender. Finally got around to fitting them today. Not had chance to try them out yet. I hope they will cut down the amount of crap that gets thrown up on to the door handles.
Post #981255 4th Feb 2023 6:09pm
steveww
Quick update. I washed Lizzy before fitting the Dirt Defenders and today I’ve been down a couple of farm tracks that are still wet and have shallow puddles. Normally this would have flung mud up the sides. Those little extra wings make a huge difference, only a few small splashes made it up the sides. Very pleased with the result.
Post #981361 5th Feb 2023 2:36pm
Sjmmarsh
United Kingdom 2009 Defender 90 Puma 2.2 XS CSW Santorini Black
Greetings from Stamford.
I too had an itch, but am a year behind you on your journey.
Steve
Post #985664 15th Mar 2023 7:35pm
steveww
Nice 90. I'm planning to get the windows tinted on mine soon.
Post #985679 15th Mar 2023 9:51pm
Sjmmarsh
I need to stop mine rattling. It looks like replacing the felt is the first stop.
Or maybe I just add a decal or two?
Steve
Post #985692 15th Mar 2023 11:21pm
steveww
Just a quick update. On Tuesday we failed to proceed because the battery had lost its mojo and only had enough go to throw the solenoid. Thanks to great help and advice from this forum a new battery was order from Tayna; excellent value and delivered next day.
It was a bit of an arse to fit because I park Lizzy in the garage with the passenger door next to the wall. Having been left overnight on trickle charge, she started first pull this morning.
I have a couple of tweaks in the pipeline, more updates soon.
Post #985800 16th Mar 2023 6:48pm
Sjmmarsh
Steve - we lead parallel lives. I had that a couple of weeks ago. Same issue with the passenger door.
In my case, I have no power in the garage so had to dead lift the battery out of its hole from the driver’s seat. I took it home and charged it but decided to push the defender out of the garage to refit it from the passenger side.
It is 50:50 whether dead lifting the battery was harder than pushing the defender out of the garage…
Post #985807 16th Mar 2023 6:58pm
steveww
A little bit of Optimil bling to brighten up the interior.
The door openers are a right PITA to fit. I kept the original plastic surrounds and they need to be trimmed to accept the Optimil alloy openers. If I never have to rummage inside a door again it will be too soon.
The door handles do not come with black screws to match which I think is a bit cheap. For now I've used some silver ones I had in stock and a black Sharpie.
Post #986310 21st Mar 2023 2:01pm
steveww
A few weeks back I fitted Fox dampers all round. Certainly a big improvement, it's not a Range Rover but the ride quality is way better than the old standard dampers. The small bumps are handled better, you notice this on a farm track of town high street. The little ridges do not jolt like they used to. It's also much better on rough country B roads, the undulations are absorbed rather than bounced over.
Not tried it fully loaded with camping gear yet....
Not an inexpensive option but worth the money FWIW.
Post #987673 2nd Apr 2023 7:52pm
