![]() | Home > V8 > 3UZ-FE conversion |
| Timbo Member Since: 15 Jun 2021 Location: west mids Posts: 136
Has anybody used this chap's stuff? https://www.ebay.co.uk/itm/173868727532?ha...SwBrRdo4Wi
With the lack of response I took the plunge and ordered the adapter plate and flywheel. Should land this week so I'll keep you posted as to it's suitability. All the best Tim
| LJMARSDEN Member Since: 08 Jun 2021 Location: Nottingham Posts: 353
Be nice to see a build thread from you mate, Im considering a 3UZ swap while using a "built" 300tdi R380 box.
Be interesting to see whho you will use for looms etc. 4.0 V8 Defender 90 My Instagram |
This is the thread you need to see this guy is another level
Oh dw I've checked it out. Looks fab 4.0 V8 Defender 90
My Instagram |
Click image to enlarge Click image to enlarge Click image to enlarge All looks good so far. The 4 smaller bolts supplied are the wrong thread and I've received a bill from Fedex for import duty I wasn't expecting Click image to enlarge Ive yet to try gearbox but a quick glance at lining it up before it was attatched to engine seemed ok just need to either drill a small hole for locating dowel on gearbox starter cut out or grind it off. Click image to enlarge These are the wires going to 2 plugs on auto box which I just cut off Click image to enlarge Clutch and flywheel fitted no problems so far. Gear box will be fitted tomorrow. Click image to enlarge Sender and fuel pump from Lexus too short to fit directly so I took it apart and put fuel pump in swirl pot from defender tank. I had to change pre filter from a side mounted one to a centraly mounted one. |
Click image to enlarge Connected gear box and trial fitted transfer box today. Had to grind a bit here and there but got it to fit. Family commitments meant this was all I managed to do this weekend Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
Making plenty of progress
did you grind that casting because of drive flange and or prop fitment issues? I won't be encountering that same problem as I plan on using standard box... Looking good Tim. EDIT: What are you using for the pump? I'll be using something roughly 250 LPH or more and possibly external from the tank. 4.0 V8 Defender 90 My Instagram |
The casting from the gearbox to transfer box needed a bit grinding of the side because of clearance as I tried to slide transfer box on some bolt heads woudn't pass. Also there was a lug on M57 gearbox which needed grinding off and a chunk of the webbing too
The pump is the original off the donor car. I heard bosch 044 is a popular pump to use. I've got to figure out linkage now. |
Very good,
linkages sound fun - Glad I've taken the easy (lazy) way out for that reason My Instagram |
My neighbour who is a classic car buff assisted me today. It fits in the gap but there's a lot to modify. Linkage is still a headscratcher engine mounts need fabricating etc etc I'll take close ups of stuff as I figure out ways to overcome each hurdle |
looks like its all getting exciting there Tim
What needs moving? Steering box in the way? 4.0 V8 Defender 90 My Instagram Last edited by LJMARSDEN on 2nd Nov 2021 7:21am. Edited 1 time in total |
Hey LJ, the steering box will foul the power steering pump so I've asked Matt to make me the relocation kit like he's done. The alternator should be ok where it is, I think I may be able to use existing toyota mounts on existing land rover brackets but with a plate bolted on to sit the engine further back. The heater box is in the way a bit but I think I can melt the box with a bit of heat to reshape it a bit
Good of Matt to help out - I might need the same kit but I should be picking up a donor car next week which is a GS430 and has a slightly different accessory system I think? (could be engine mounts I'm thinking of actually)
are you on a pre TD5 chassis? It would be so handy if the stock rad/ fan can fit nicely in there - fingers crossed 4.0 V8 Defender 90 My Instagram |
Mines an 08 puma was 2.4
| All times are GMT |
