Home > V8 > 3UZ-FE conversion
Timbo
England 2008 Defender 110 Puma 2.4 USW Tonga Green
3UZ-FE conversion
Has anybody used this chap's stuff? https://www.ebay.co.uk/itm/173868727532?ha...SwBrRdo4Wi
Post #919875 3rd Sep 2021 9:43pm
Timbo
With the lack of response I took the plunge and ordered the adapter plate and flywheel. Should land this week so I'll keep you posted as to it's suitability. All the best Tim
Post #922916 26th Sep 2021 10:10pm
LJMARSDEN
United Kingdom 2006 Defender 90 Td5 HT Java Black
Be nice to see a build thread from you mate, Im considering a 3UZ swap while using a "built" 300tdi R380 box.
Be interesting to see whho you will use for looms etc. Instagram: https://www.instagram.com/the_black_td5/
Post #923040 27th Sep 2021 4:37pm
Timbo
This is the thread you need to see this guy is another level Laughing https://www.defender2.net/forum/topic73015.html
Post #923104 27th Sep 2021 9:32pm
LJMARSDEN
Oh dw I've checked it out. Looks fab Instagram: https://www.instagram.com/the_black_td5/
Post #923116 27th Sep 2021 10:28pm
Timbo
All looks good so far. The 4 smaller bolts supplied are the wrong thread and I've received a bill from Fedex for import duty I wasn't expecting Big Cry The starter motor bolts hold the plate off a little so I ground out the back of the plate with a dremel
Ive yet to try gearbox but a quick glance at lining it up before it was attatched to engine seemed ok just need to either drill a small hole for locating dowel on gearbox starter cut out or grind it off. Confused
These are the wires going to 2 plugs on auto box which I just cut off Rolling Eyes
Clutch and flywheel fitted no problems so far. Gear box will be fitted tomorrow.
Sender and fuel pump from Lexus too short to fit directly so I took it apart and put fuel pump in swirl pot from defender tank. I had to change pre filter from a side mounted one to a centraly mounted one.
Post #924292 3rd Oct 2021 9:52pm
Site Copyright © 2006-2021 Futuranet Ltd & Martin Lewis
