![]() | Home > Technical > Bulkhead Strip down & Removal |
| Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3784
Ignore this post. Just told you how to remove the dash on a puma, which was pretty pointless!
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6042
Here is a link to what my td5 110 looked like.
https://www.defender2.net/forum/topic49854...t=bulkhead Might give you a few ideas 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
| donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1917
To be honest, though the job's been done a lot, it's really very 'bitty' - by which I mean lots of little fixings and components, though none of it is very technical.
What I'd suggest is to take lots of pictures as you go, so you have references for the rebuild, and can hopefully avoid the hassle of fitting something before realising you should have fitted something else first. For example,don't fit the dash backing panel before fitting the windscreen wiper tubes (not a great example, but hopefully you'll get what I mean). Also, have a bunch of egg boxes and plastic bags and labels to hand to make sure that you can keep things organised. This is the place to ask specific questions though. I've had my dash out a couple of times, bulkhead once,but I've done two other bulkheads too. Not as especially technical job, but a bit involved. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3648
I have placed some pictures in my restoration thread, pg12, however not an account how to strip or assemble.
https://www.defender2.net/forum/topic72365-165.html But I try to give a short account to remove the dash here (hopefully without too many mistakes): 1. First to remove is the binnacle, and the heater controls 2. Remove passenger side grab handle and wiper motor cover 3. Remove top dash. There are screws on the underside too. 4. Remove plastic rivets and Gently pull out the grey plastic trim. Very fiddly. Mine is pre 2002 design. You have to press it almost to the point of breaking it. Just cross your finger that it does not. 5. Remove the windscreen demister and the metal panel that was behind the greyish plastic trim. 6. Remove the lower dash. There are 2 M5 screws at the top side, one would be behind the harness. There are of course the self tapping screws around the bottom edge. To install is the reverse procedure. Putting the greyish plastic trim back in was very difficult. I spent the best of 2hrs trying to get it in as delicately as possible, as I was working with 33 year old plastic. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
On the link I posted is a list of bits I ordered for when mine was done. Some I knew would need replacing, others were just in case. 1999 Defender TD5 110
