Home > My Defender > Puma to LT1/8L90 Restomod
Page 16 of 41 <123 ... 151617 ... 394041>
mrfirepro
United Kingdom 1996 Defender 90 300 Tdi HT Bonatti Grey
Thanks thats great to know, good read. Was also thinking about shortening the studs that go through the rear cross memeber (good Idea/ Bad idea??)
Post #897919 13th Apr 2021 9:51am
Co1
I didn’t need to in order to fit it, and there isn’t a load of spare thread hanging out the back once the nuts are on, so I wouldn’t bother.
Post #897921 13th Apr 2021 9:53am
Linds Hanson
I still think its a much better engineering solution to put a access panel in the rear floor whilst you have it stripped down. its what Land Rover should of done and did on Discovery. I was certainly glad on the last pump I fitted as the fuel gauge didn't read right when I road tested it so swapping the pump again wasn't a big deal.
Post #897976 13th Apr 2021 2:02pm
mrfirepro
thanks for the tips!
Sandblasted - you were right, didn’t take much blasting the paint literally fell off Shocked )
and painted PAS box (EM121, did I say I like EM121 Laughing )
Prep to fix fuel tank cradle from below
Just need to weld up the old holes in the cradle and repaint.
Finally got the new bits for the brakes (Ceika-store.com = Nightmare)
Got the tyres fitted to the rims with the TPMS sensors installed
Made some larger disks to protect the ABS sensor and ring from road debris.
I was finally able to install the new ASB sensors with bush
One side finished, installed the 300m drive shafts and HD flange
Still WIP but have started to install the onair suspension system, really quite impressed with the quality also the technical support is excellent.
fronts
Rears
Hopefully the next couple of weeks will get the chassis rolling, I'm still waiting for the mounts and adapter from RW Eng in the states, Mad
Post #899014 19th Apr 2021 3:36pm
Co1
Bow down
Post #899037 19th Apr 2021 7:00pm
mrfirepro
Not far away from a rolling chassis, just need to build up the front hubs.
Got the first bit of paint on the bulkhead. But this is the bulkhead before paint.
with paint
Real tricky job fitting the ashcroft drive shafts to the CV's, seems the snap ring just had a mind of it's own, got there eventually tho...
welded up the old holes in the cradle and repainted so it can be removed from below, top tip thanks Thumbs Up
Post #900001 26th Apr 2021 12:00am
mrfirepro
Now the bulkhead is back I'm planning on spraying some epoxy mastic (EM121) on the bottom and I've bought some Dynomat Extreme to put on the inside.
I've been reading some old threads on sound deadening and I'm still not clear if I should completly cover the whole of the inside of the bulkhead or not and if I cover the inside does everything still fit in place?
Advice is much appreciated....
Post #900611 29th Apr 2021 8:30pm
Pickles
Very nice workmanship here, what diameter are those magic looking brakes?
Pickles.
Post #900627 29th Apr 2021 10:34pm
mcma1
Post #900641 30th Apr 2021 6:04am
mrfirepro
Pickles - The brake rotors are 405mm with 8 pot calipers, however there is a fitment issue, the calipers are binding on the lower track rod end, so looks like 8 pots are out of the question going forward.
The caliper bracket binds on the TRE
Caliper fitment problem
Been fitting some of the on-air suspension parts
Rear height sensors
The front height sensor does not fit as per the manual, on-air have told me they have not seen this arrangement with the extra webbing behind the bulkhead outriggers, however it's the same on my original LR chassis, so got to come up with a solution that fits. This is the extra webbing and with the new sensor placement.
Won’t be a lot of clearance for unplugging the sensor.
Air reservoir installed.
Lower bulkhead and galvanised brackets coated with EM121.
Going to start fitting the dynamat to the inside of the bulkhead over the next weekend, not quite sure how that going to work out..........
Still no news on the engine mounts and LT230/8L90 adapter from RW-Eng in the states, I'm hopeful for early June
Post #901425 4th May 2021 11:08pm
Pickles
Wow,..405MM, that is huge, & 8 piston calipers,...I have 410mm 6 piston APs on our HSV GTSR, and they are the biggest brakes ever fitted to an Aussie car!
Surely with all of the engineering/planning you have done, you will be able to find a way around the caliper issue,..different brackets maybe?
So can you still use the 405mm disc with a 6 piston caliper?
Following your build with great interest.
Pickles.
Post #901427 4th May 2021 11:41pm
mrfirepro
Finished the dynamat on the inside of the bulkhead
couldn't resist putting the wheels on even though they will need to come off again when I finally sort the brake calipers, really can't get on with much except building the bulkhead.
can anyone suggest some descent centre caps??
Post #902492 10th May 2021 11:06pm
jimbo55
Wow, really looking good!
Surprised on air haven’t seen the bulkhead bracing before, it’s been there since about 2002 if I remember correctly!
For the callipers, have you considered getting new adapters made? Couldn’t you rotate the calliper around the frisk slightly to give you the clearance you require on the track rod end?
Post #902519 11th May 2021 8:14am
mrfirepro
Jimbo,
Thats the plan, they are going to make then in the next couple of weeks. The only issue is clearance on the top swivel mount, I'm still a little concerned that the mount is going to be thiner than before. This is the concept drawing I sent them.
The only other thing is that I may have to cut away part of the sheild
this is the current clearance so it's all so very close
Post #902534 11th May 2021 10:06am
Co1
Looking forward to hearing is fire up for the first time. Does the LT1 shut down 4 cylinders when cruising?
Post #903068 14th May 2021 7:01pm
