Home > My Defender > Puma to LT1/8L90 Restomod
Page 5 of 41 <123 456 ... 394041>
JOW240725
As above Defenders like to rot, so any rust proofing you can do is well worth it, see https://www.defender2.net/forum/topic10467.html .
Later down the road you should also consider sound insulation and most importantly security!
Good luck! Exciting!! James
Instagram @suffolk_rovers
Post #876205 4th Jan 2021 4:06pm
mrfirepro
United Kingdom 1996 Defender 90 300 Tdi HT Bonatti Grey
Got photos working now.
This was why it's an 8K Puma
2021-01-03 10-26-09
This is what it looks like as of yesterday, didnt have a lot of time but progress was slow, real faf with the wings, I'm sure you know that.
2021-01-05 16-54-28
Post #876584 6th Jan 2021 11:15am
Procta
how badly is the chassis on the front? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #876592 6th Jan 2021 11:59am
mrfirepro
I'm not sure yet, that will be the first job when it's stripped. I'd really like to keep the original, clean it, galvanise it and then treat it to a coat of EM121.
The impact was enought to shear the half shaft, so I'll be a little suprised if it's OK.
Post #876606 6th Jan 2021 1:03pm
Defendermatt
United Kingdom 1989 Defender 90 Other SW Bonatti Grey
Check the OS radius arm mount, I had one similar - big impact to the front wheel. It had bent the radius arm chassis mount, radius arm, axle casing and smashed the swivel housing. 1989 90 4.3 V8
2012 L405 OF
2014 D4 HSE Lux (SOLD)
2015 90 HT (SOLD)
@d9o.mf
Post #876616 6th Jan 2021 1:27pm
Co1
That’s got loads of potential to be a really smart looking landy. Watching this one with interest, good luck with it. Thumbs Up
Post #876729 6th Jan 2021 7:44pm
mrfirepro
Quick question, which to remove first Bulhead or engine???
Sorry of it's a dim question
Post #876878 7th Jan 2021 4:33pm
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
I'd be tempted to remove the bulkhead first, removing as few brackets etc. as possible, then lift the engine and transfer/gearbox out as a single lump.
I've done it in reverse before on earlier models but it's a faff. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #876890 7th Jan 2021 6:02pm
mrfirepro
managed to get some time today, this is where I'm at right now
questions
1. Can the aluminium tub be repaired, there are some areas of galvanic corrosion, where steel meets the tub at the bottom corners, (where the tub meets the front doors) and behind the brackets that have the fixings for the inertia reels.
2. As I'm (hopefully if I can find a loom) upgrading to an XS spec loom (Electric windows, heated screen and seats, ABS, TC and AC) I'd like to try and install ABS, I got the controller sorted through Martin at Futurenet, and I think the front axle looks like it can be modified, I'm not sure about the rear axle. Any pointers or advice apperciated.
3. If anyone knows of any XS's being broken I'd be interested to know or ABS rear axles (several on eBay at £660, seems high?????)
My observation, as it's my first LR experience, is that I'm suprised how much corrosion there is in the brackets and the fixings at least 20% of the fixings were so badly corroded they had to be cut or drilled out or just broke. I can't begin to imagine what this would have been like in another 5-10 years.
A few more random pics
Post #876944 7th Jan 2021 10:17pm
mini Anaconda
Keep up the good work Thumbs Up BORG - Bucks & Oxon 4x4 Response Group
Post #876947 7th Jan 2021 10:24pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
What's the deal with the engine your removing?
Post #876964 8th Jan 2021 12:43am
mikeh501
Just keep pulling it apart. looking at the photos your either going to refurbing lots and lots of components or buying new. cost/time etc. I would definately get friendly with YRM parts lol, they will be your friend for shiny new galv bracketry.
Post #876983 8th Jan 2021 10:01am
mrfirepro
MIkeH501 - Thanks YRM parts look great, almost everything will need to be replaced, thanks for the advice
Badgert - Engine is great just replacing it with an LS3
Post #876999 8th Jan 2021 10:45am
mikeh501
Suffice to say i've spent more than i care to mention with them! The stuff they sell is great and i've not had anything duff from them. Mine is either galved or stainless throughout, like literally everywhere I reasonably could.
Post #877008 8th Jan 2021 11:15am
mrfirepro
Mike, that looks great.
Having seen the ammount of galvanic corrosion, when you use stainless are you attempting to isolate the contact between the two metals.
Post #877012 8th Jan 2021 11:24am
