Home > Puma (Tdci) > (sorry) need to pick clutch/output upgrade parts |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2232 |
I've not done it in situ. I imagine it could be done, but you would probably wish you didn't!
The diff comes out through the front once you remove the front output housing but it won't come until you pull the intermediary shaft and drop the intermediary gears. If the clutch is being done then the diff could be checked once the transfer box is off? > 110 XS Double Cab > Instagram @simonlanemind |
4th Sep 2020 1:21pm |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5765 |
Thank you both. Monsieur Le Grenadier
I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
5th Sep 2020 8:32am |
Gasket Member Since: 30 May 2020 Location: Manchester Posts: 629 |
Clutch ordered: went for Clutchfix kit with the 2.2 slave and parts. Thanks guys - Will report back on how it changes the drive.
6th Sep 2020 11:12am |
Hi al - just to close this out.
I had a clutchfix kit fitted along with the 2.2-spec concentric release bearing and the ashcroft output shaft. Result was that it drive like a standard vehicle though with notably less spring noise. Plus I’m now know it’s done and that it will last me for many thousands of miles. The big change was the rear halfshafts: had the 2-piece design (which was very worn) replaces with britpart 1-piece shafts and it has dramatically improved the drive. I had a significant driveline ‘thunk’ which has now gone away completely. Very happy with all the works and thanks again for your help. |
3rd Oct 2020 10:24pm |
