![]() | Home > My Defender > Grafty's Td5 90 |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
This very forum
![]() ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
Glad you got one sorted. QRZ 2e0vpf
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6714 ![]() ![]() ![]() |
Yes 29 for clutch, 4 for fan. If you need more pins for the ECU plug let me know.
Yeah, pretty busy at the moment - full until the middle of September at least
![]() Thanks GREENI - sorted the same day funnily enough ![]() Thanks again Martin - will tackle that on Friday, hopefully ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11074 ![]() ![]() |
Might even be longer as you might get an influx of people down once the schools go back
Could well be! I can usually finish earlier on a Friday so if you're still working close by on Friday afternoon then drop me a text
Will do George
Managed to get a couple of hours in after work yesterday to finish the AC install off on the 90. Both the condenser fan and compressor clutch are now controlled by the ECU.
![]() Using the Nanocom I could test the ECU outputs and trigger the fan and compressor clutch - it all works! Luckily the wires were already in the loom for the relay coil wires. I traced them as far up the loom as I could and cut them. They were then long enough to crimp the relay base terminal straight on. Booked in for pressure testing and gassing on Wednesday. If nothing leaks then it should be fully functional ![]() Once that's done, the only thing my 90 doesn't have is ABS/TC. So at the moment it's and XS- ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5369 ![]() ![]() |
Neat little upgrade,
![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Had the AC gassed up today, zero leaks and fully gassed with 750g of gas and 100ml of oil. Its absolutely ice cold. The compressor and fan are cutting in and out as they should - all ECU controlled. Happy chappy!
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3357 ![]() ![]() ![]() |
Good work George. Did you manage to keep the LED bar behind the aircon grille? WARNING.
This post may contain sarcasm. |
So your ready for the next heatwave then George
Yes Zed, lightbar is still in place. It sits below the condenser so all good there
How hard was it to install? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
