Home > General & Technical (L663) > 2020 Defender main discussion thread
This topic is locked: you cannot edit posts or make replies.  Down to end
Page 175 of 351 <123 ... 174175176 ... 349350351>
Naks
Post #827349 24th Apr 2020 12:14pm
dailysleaze
Good to see it floundering in the mud at 05:38
Post #827447 24th Apr 2020 8:07pm
J77
I believe that’s the area in which they get the car stuck in order to demonstrate the winch.
Post #827478 24th Apr 2020 9:36pm
Thought he nearly had it on the early tries but never really committed enough to the throttle early on ~ maybe deliberately so if the intention was to play with the winch?
Post #827512 25th Apr 2020 7:04am
Naks
Land Rover Defender spied testing with a V8: https://www.autoblog.com/2020/04/24/land-r...de-2227525
Quote:
Yes, although it may look like any ordinary 2020 Land Rover Defender, this test vehicle actually has a 5.0-liter V8 under the hood. How could we know? Well the spy photographer and his team that provided these photos ran the plates and discovered the car is registered as having such an engine.
There's also a very small exterior detail that reveals this Defender doesn't have either the turbo four-cylinder or six-cylinder. At the back, there are dual exhaust outlets with a quartet of tips. The recently released Defender with the other engine options has a solitary outlet on the left side. Not only that, but the muffler the tips are attached to is shaped differently compared to other Defenders.
Adding a V8 shouldn't be particularly difficult. The Defender shares a large selection of components with the much larger Range Rover. It even shares its new straight-six with the big SUV. And going down this Range Rover parts bin line of thinking, it could get one of the model's V8s.
The base one makes a whopping 518 horsepower and 461 pound-feet of torque. The upgraded one makes 557 horsepower and 516 pound-feet of torque. The base one would seem more than adequate for the relatively small Defender, but hey, in a world of 700-horsepower Jeeps, why not go big?...
Post #827527 25th Apr 2020 8:59am
Naks
New Land Rover Defender X P400 review: https://www.evo.co.uk/land-rover/defender/...400-review
Quote:
... This P400 mild-hybrid is currently the only straight-six available in the Defender, although a diesel will arrive soon enough, with the 3-litre unit featuring both a conventional twin-scroll turbocharger and a 48V electric supercharger. There’s also a belt-integrated starter motor in lieu of an alternator, with a 48V lithium-ion battery that stores recuperated energy as the car slows.
Combined, these two elements produce 394bhp and 406lb ft of torque, making this the most powerful Defender in the company’s history. The quickest, too, with a 0-60mph time of 6.1sec and a 129mph maximum if you go for the optional 22-inch wheels, otherwise you’re pinned back to 119mph.
There’s a claim of 29.4mpg, but we did struggle to get out of the teens on our drive. Perhaps a longer run on a motorway would help rather than a mad dash across the Fosse Way in the Cotswolds. ...
What's it like to drive?
Nothing like a Defender of old, which some of you will be more than happy about while others will head straight outside to hose out the interior of their ‘real’ Defender. But it’s 2020 and having a car that drove like it was designed to survive being dropped from a plane makes for a lovely piece of nostalgia, but not such a great car.
In the new Defender you’re driving a car that works on road as well as it does off it. It doesn’t lurch around or pitch itself into a corner or around a motorway slip road curve with the grace of an elephant on skates. It drives like a normal car. It drives better than most car-based SUVs.There’s a suppleness to its ride quality that puts the Discovery 5 to shame and its body control is superior, too. It certainly responds to being hustled along better than the 5, and aside from the slightest evidence of vagueness from the steering around the dead ahead when the optional off-road tyres are fitted, you find yourself travelling quicker than expected.
The thump from the straight-six helps considerably here, neither troubled by the 2443kg kerb weight nor aerodynamics that probably raised a snigger from the wind tunnel operators. Its step-off from stationary is instant, the mid-range punchy and responsive beyond all expectations, and it even enjoys troubling the red line. Unlike its predecessor and so many of its ilk, it lets you set the pace rather than dictate it. For those long road trips and too far away places that Defenders are drawn to, the road part will no longer be a chore.
Your overriding impression of the new Defender is just how complete it feels. How nothing has been compromised or sacrificed and every need has been catered for. It will still crawl up a rock face or submerge itself in a bog and haul itself out the other end, but crucially it will no longer suck the life out of you when you need to travel any distance on a road. ...
Post #827529 25th Apr 2020 9:10am
22900013A
I would probably feel better about the new model if every review didn't devote a third of the copy to just slagging off the old model. It's boring, insulting, and frankly its sloppy journalism. 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #827534 25th Apr 2020 9:29am
Grenadier
^^^ It could be argued that that is either JLR's fault or McGovern's fault. If JLR hadn't allowed this new model to be called 'Defender' or McGovern hadn't decided that it should be the successor to our Defenders, then the comparison would never be made. By calling it Defender, selling and marketing as Defender, getting the PR machine working full time to allude to how good this Defender is (and whilst not directly saying so, implying that the old one wasn't as good, iconic or not), a journalist is automatically going to compare the two. I also have no doubt that the differences between old and new are rammed down their throats during their JLR organised test days. It'll only change when the vehicle is on the open market and available for journos to test them independently and compare them alongside other brands. Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #827554 25th Apr 2020 10:39am
J77
I recall my salesman saying they had to get stuck and winch the car out, but as the day went on it became a swamp. Unlucky for the last group of the day.
Post #827555 25th Apr 2020 10:43am
zilch
Australia
Naks wrote:
Land Rover Defender spied testing with a V8: https://www.autoblog.com/2020/04/24/land-r...ide-222752
Neat find Naks yet another pommie bar steward down under
MY20 110 P400 SE Defender
MY10 3.0 RR Sport
Post #827566 25th Apr 2020 11:37am
Tim in Scotland
The Gondwana Gold V8 prototype in the link posed by NAKS looks like it has severe bramble rash .................or the expensive clear wrap is quite matte finish Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #827577 25th Apr 2020 12:51pm
J77
The wrap gives a matt effect. Personally not a fan, I’d rather pay a fraction of the price and get one of those clear wraps.
Post #827578 25th Apr 2020 1:18pm
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Chassis number identifies it as a 3.0 Petrol...
Post #827579 25th Apr 2020 1:26pm
DSC-off
^ Take a standard I6 model off the production line. Deliver it to the SVR Engineering dept. Fit V8 engine, gearbox and electrics.
Job done, one prototype V8 Defender.
It even says "Prototype vehicle" on the front grille.
Post #827599 25th Apr 2020 3:23pm
So what search did they do on the reg? I've just used the Gov one and it didn't say V8?
Post #827601 25th Apr 2020 3:33pm
This topic is locked: you cannot edit posts or make replies.  Back to top
