Home > Maintenance & Modifications > Corrosion Prevention Guide! |
MalithS Member Since: 30 Jun 2015 Location: Midlands Posts: 38 |
Many thanks to Zagato for sorting my 90 out. Brilliant work and highly recommended. Underneath the car is looking great now with the Corroheat applied.
Ordered my tin of ACF50 this morning to I can keep on top of things as well |
24th Oct 2019 10:36am |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4789 |
Certainly looks very nice 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
24th Oct 2019 9:10pm |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 4990 |
SNAP! well nearly, little brother is in for full treatment and a few mods
Both 14 plates. Click image to enlarge Last edited by Zagato on 10th Nov 2019 11:39am. Edited 1 time in total |
10th Nov 2019 11:37am |
This is particularly nice
Click image to enlarge And so is the cake, many thanks to Nigel's wife delicious Click image to enlarge |
10th Nov 2019 11:39am |
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3334 |
Thanks for all your hard work on our Defender, Chris. It's safely back into darkest Norfolk now.
Luckily no issues at the border control between Suffolk and Norfolk Glade you like the cake as well as our USW Great picture with its little brother. I do like the look of a 90 and if my numbers come up, I will be adding one to my collection to keep our 110 company If anyone has been having thoughts about getting their truck protected, Chris has done an A1 job for us. Can't recommend his work highly enough Thank you again, Chris |
10th Nov 2019 3:34pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7873 |
Glad you made it safely thru' Suffolk! James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
10th Nov 2019 5:44pm |
Me too Luckily, the draw bridge was down when I reached Elveden
10th Nov 2019 6:18pm |
G_unit Member Since: 14 Nov 2019 Location: high peak Posts: 16 |
I know I’m coming into this at the wrong time of year perhaps, but I’ve decided to get the underside of my 90 sorted out before subjecting it to the salty roads where I live, they’ve been out gritting a few times now. I’ve already bought a great load of products from bilt hamber and I’ve started on the underneath today, giving it a thorough clean all over the chassis and going at it with the abrasives. The problem I have is that the truck lives outside, and I want to ensure it’s completely dry before applying anything as I will be using the bilt hamber epoxy mastic so I don’t want to seal anything in. Does anyone have any good tips for making sure it’s bone dry inside and out? My plan is to get under with a heat gun and fill the insides of the chassis firstly with bh atom Mac which is supposed to disperse water, then fill them right up with dynax s50. Then the outside will get a coat of the mastic. I have already treated the few spots of rust that I can see with bh hydrate 80 rust converter. Does this sound anything like or will I start seeing problems in a couple of years? sorry for the novel but I am concerned about this one and am planning on having it as a keeper.
Cheers |
16th Nov 2019 5:51pm |
Warning g-unit, nothing disperses moisture completely, (its ) apply any solution and it will push water of course BUT moisture "soaks" into metal, especially welds which you have runnning along the entire length of your chassis. Drying is paramount, you will make things worse by covering moisture of course, you will have to decide what is best for this in your circumstances. Not easy if working from home outside without proper equipment! I only used Bilt Hamber once for reasons previously stated, so cannot advice on your products.
2nd Dec 2019 7:19pm |
One of my regular customers and one of my favourite Defenders. Now refreshed underneath and with a cleaned/polished body Three layers of Underbody Dinitrol and three layers of body wax will keep her mint over winter
Click image to enlarge And something completely different and rotten because somebody had filled the chassis with waxoyl and sealed it in. Never do this, you get condensation in box sections and waxoyl becomes a thick cakey mess in as little as two years and acts like a wet sponge just holding water against the chassis... disaster, much welding and fabricating going on now, nearly finished. Use Dinitrol cavity 1000 treatment folks, yes they have changed the name again! It will never soak up moisture... Waxoyl is a 1960's technology like the car simply oil, wax and white spirits Click image to enlarge Wet waxoyl cut and peeled back to show wet rust underneath. Waxoyl peeled off other areas showing rot on already replaced fabricated metal. Apart from it becoming soaked as it is only wax and oil which does not resist water after a year or so, it shrinks letting water in down the sides and underneath as it does not seal onto metal. Click image to enlarge |
2nd Dec 2019 7:24pm |
The whitish/yellow stuff, bottom inside is the wet waxoyl. The moisture has been sitting on the lower sides where the waxoyl has shrunk... and underneath of course, holed also. It was so full of waxoyl, we had drops of it on fire dripping down as we welded. If you have this situation I would open up the drain holes and heat the chassis up, get out as much as you can, then 360 degree spray with ACF-50 then once again with Dinitrol 1000.
2nd Dec 2019 8:33pm |
treps Member Since: 07 Jul 2015 Location: SE Posts: 244 |
The Adventure is looking excellent. Thank you. I look forward to picking it up tomorrow.
Anyone still with doubts on the effectiveness of the ACF 50 treatment applied by Chris, just look at the end result. Brilliant [quote="Zagato"]One of my regular customers and one of my favourite Defenders. Now refreshed underneath and with a cleaned/polished body Three layers of Underbody Dinitrol and three layers of body wax will keep her mint over winter Click image to enlarge |
2nd Dec 2019 8:54pm |
Great looking Adventure Treps Great work Zagato Rading these I always wish I had my Defender from new and treated before use and regularly after!
Any plans to move to Suffolk Zagato? James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
3rd Dec 2019 3:26pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 3995 |
For those of us brave/stupid enough to want to do DIY application of Dinitrol, is there any effective way to clean the chassis without access to a steam cleaner? I did mine a few years ago with just a pressure washer and soap and it really doesn't get all the crud off. It needs doing a again now and wondering how to do a better job of cleaning it. 2007 110 TDCi Station Wagon XS
2nd Jan 2020 5:45pm |
