shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 ![]() ![]() ![]() |
![]() Click image to enlarge Took it to the beach this morning -Deltabre Catalunia ![]() Click image to enlarge Saw these on the way. Just because you're offended doesn't mean you're right. |
ak615 Member Since: 22 Aug 2018 Location: essex Posts: 190 ![]() |
Reached a milestone
![]() Click image to enlarge Then a little bit of OCD kicked in ![]() ![]() Click image to enlarge |
![]() Last edited by ak615 on 24th Oct 2019 4:26pm. Edited 1 time in total |
DG123 Member Since: 29 Aug 2015 Location: North West Posts: 138 ![]() ![]() ![]() |
Continued trying to get the back of the 110 dry.
Are there supposed to be big panel gaps behind the C-post (back of the rear seat box where it meets with wheel arch)? These are both sides on mine so don’t want to fill if they are some kind of drainage, although definitely ‘inside’ the car. ![]() Click image to enlarge ![]() Click image to enlarge Didn’t find anything else immediately obvious 2012 110 XS SW Orkney Grey 2003 D2 Td5 Black [SOLD] |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6013 ![]() ![]() ![]() |
Noticed on a 30 mile motorway drive, engine temp normal but little or no heat out the vents
![]() As a precaution, ordered a Gen LR thermostat - looks like a job on my day off. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 370 ![]() ![]() ![]() |
Check the coolant level first - mine did exactly the same and it was the first indication of a slow loss of coolant. Dave
Green Goddess - 1998 Defender 110 300tdi |
Cheers. I hope not, it had a new AMC head 7 odd years ago. ! 1999 Defender TD5 110
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2148 ![]() ![]() ![]() |
as above - check coolant as this happen to me a few times with our TD5 ![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
Coolant about 10-15mm below the join in the header tank. 1999 Defender TD5 110
Top it up and see what happens ...
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20916 ![]() ![]() |
Bear in mind that coolant fluid level naturally tends to settle a little bit below the marker line.
If it keeps going down and down though that's another thing all together. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Yep the plan is to top up and see what gives. Sunday I am planning on swapping thermostat if the heating does not improve 1999 Defender TD5 110
I was planning on replacing the thermostat on Sunday, but the job is now on hold as I spotted the intercooler pipe has been rubbing on the water pump to thermostat pipe. So I decided to replace this pipe as well (but need to order it) and waiting will save dropping the coolant twice. 1999 Defender TD5 110
