Page 1229 of 1392 <123 ... 122812291230 ... 139013911392>
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Took it to the beach this morning -Deltabre Catalunia
Saw these on the way. Just because you're offended doesn't mean you're right.
Post #798837 20th Oct 2019 12:40pm
ak615
Reached a milestone
Then a little bit of OCD kicked in Laughing
Post #799334 24th Oct 2019 4:25pm
ak615
Very Happy
Post #799335 24th Oct 2019 4:25pm
ak615
Very Happy
Post #799336 24th Oct 2019 4:25pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Finally got it back from the bodyshop 11 days after they took it for a 3 day job.
To be fair, the work looks good though. 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #799341 24th Oct 2019 4:29pm
DG123
Continued trying to get the back of the 110 dry.
Are there supposed to be big panel gaps behind the C-post (back of the rear seat box where it meets with wheel arch)? These are both sides on mine so don’t want to fill if they are some kind of drainage, although definitely ‘inside’ the car.
Didn’t find anything else immediately obvious 2012 110 XS SW Orkney Grey
2003 D2 Td5 Black [SOLD]
Post #799416 24th Oct 2019 11:58pm
excossack
Noticed on a 30 mile motorway drive, engine temp normal but little or no heat out the vents Sad
As a precaution, ordered a Gen LR thermostat - looks like a job on my day off. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #800159 31st Oct 2019 8:57am
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
Check the coolant level first - mine did exactly the same and it was the first indication of a slow loss of coolant. Dave
Green Goddess - 1998 Defender 110 300tdi
Post #800160 31st Oct 2019 9:00am
excossack
Cheers. I hope not, it had a new AMC head 7 odd years ago. ! 1999 Defender TD5 110
Regards
John M0VAZ
Post #800161 31st Oct 2019 9:04am
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
as above - check coolant as this happen to me a few times with our TD5
Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #800163 31st Oct 2019 9:56am
excossack
Coolant about 10-15mm below the join in the header tank. 1999 Defender TD5 110
Regards
John M0VAZ
Post #800217 31st Oct 2019 6:54pm
wyvern
Top it up and see what happens ... Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #800219 31st Oct 2019 7:18pm
Bear in mind that coolant fluid level naturally tends to settle a little bit below the marker line.
If it keeps going down and down though that's another thing all together. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #800220 31st Oct 2019 7:23pm
excossack
Yep the plan is to top up and see what gives. Sunday I am planning on swapping thermostat if the heating does not improve 1999 Defender TD5 110
Regards
John M0VAZ
Post #800226 31st Oct 2019 8:00pm
excossack
I was planning on replacing the thermostat on Sunday, but the job is now on hold as I spotted the intercooler pipe has been rubbing on the water pump to thermostat pipe. So I decided to replace this pipe as well (but need to order it) and waiting will save dropping the coolant twice. 1999 Defender TD5 110
Regards
John M0VAZ
Post #800383 1st Nov 2019 8:24pm
