![]() | Home > Technical > Recommend a breaker bar for Td5 stake nut please |
| ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967
As above cheers Chris
Strange I’ve heard nightmare stories about removing them 🤔
| Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674
Assuming you are on about the stake nut on the axle I’ve always just used a 1/2dr socket on my impact gun, any good quality breaker bar would do just avoid the chinesium stuff from eBay
| miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1791
I had no issues removing the axle but with my normal breaker bar, which I think is a Halfords advanced one
| Fatbaron Member Since: 12 Mar 2016 Location: Devon Posts: 299
I always use scaffolding poles and keep a few different lengths in the workshop. Cheap and un-bendable!
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18052
Far from unbendable! Over the years I have bent many scaff tubes, albeit not on the Defender.
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8491
Halfords ones are as good as any for casual user. Cheers
| boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 751
I can vouch for the Halfords breaker bar. Worked fine on mine.
| hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2363
I too can vouch for the halfords 1/2" drive. Found one at the side of the road probably 15 years ago. It's done everything I've thrown at it, including leveraging a 4ft scaffold extension. Did the axle stake nuts with it six months or so back too no problem > 110 XS Double Cab
Thanks fellas 👍
| X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304
Halfords Professional Breaker Bar 24" 1/2" Drive £28
Purchased to use in conjunction with 52mm Wheel Bearing Stake Nut Socket A 2M length on Key Clamp Scaffoldoing was used over the top of this to break them loose, at 210 Nm / 150lbf.ft...man they are tight Basic Bar on its own is a good one...seems up to the jobs asked of it... Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
| All times are GMT |
