Home > Technical > Recommend a breaker bar for Td5 stake nut please
ibexman
As above cheers Chris
Post #764572 20th Mar 2019 11:21pm
dailysleaze
I've found a 24 inch, 1/2 inch drive breaker bar can take the nut off without tapping out the staked section, no problem
Post #764574 20th Mar 2019 11:43pm
ibexman
Strange I’ve heard nightmare stories about removing them 🤔
Post #764578 21st Mar 2019 12:33am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Assuming you are on about the stake nut on the axle I’ve always just used a 1/2dr socket on my impact gun, any good quality breaker bar would do just avoid the chinesium stuff from eBay Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #764582 21st Mar 2019 1:58am
miker
I had no issues removing the axle but with my normal breaker bar, which I think is a Halfords advanced one
Post #764583 21st Mar 2019 2:01am
Fatbaron
I always use scaffolding poles and keep a few different lengths in the workshop. Cheap and un-bendable! Thumbs Up
Post #764596 21st Mar 2019 7:50am
Far from unbendable! Over the years I have bent many scaff tubes, albeit not on the Defender.
Post #764610 21st Mar 2019 8:43am
jst
Halfords ones are as good as any for casual user. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #764613 21st Mar 2019 8:55am
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
I can vouch for the Halfords breaker bar. Worked fine on mine.
Post #764633 21st Mar 2019 10:54am
hank
I too can vouch for the halfords 1/2" drive. Found one at the side of the road probably 15 years ago. It's done everything I've thrown at it, including leveraging a 4ft scaffold extension. Did the axle stake nuts with it six months or so back too no problem > 110 XS Double Cab
Post #764634 21st Mar 2019 10:57am
ibexman
Thanks fellas 👍
Post #764637 21st Mar 2019 11:19am
X4SKP
Halfords Professional Breaker Bar 24" 1/2" Drive £28
Purchased to use in conjunction with 52mm Wheel Bearing Stake Nut Socket
A 2M length on Key Clamp Scaffoldoing was used over the top of this to break them loose,
at 210 Nm / 150lbf.ft...man they are tight Exclamation
Basic Bar on its own is a good one...seems up to the jobs asked of it... Thumbs Up
 SKIP
Post #766493 2nd Apr 2019 9:56am
