Home > Technical > Recommend a breaker bar for Td5 stake nut please |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2875 |
As above cheers Chris
20th Mar 2019 11:21pm |
Strange I’ve heard nightmare stories about removing them 🤔
21st Mar 2019 12:33am |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
Assuming you are on about the stake nut on the axle I’ve always just used a 1/2dr socket on my impact gun, any good quality breaker bar would do just avoid the chinesium stuff from eBay 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
21st Mar 2019 1:58am |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1758 |
I had no issues removing the axle but with my normal breaker bar, which I think is a Halfords advanced one
21st Mar 2019 2:01am |
Fatbaron Member Since: 12 Mar 2016 Location: Devon Posts: 297 |
I always use scaffolding poles and keep a few different lengths in the workshop. Cheap and un-bendable!
21st Mar 2019 7:50am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16883 |
Far from unbendable! Over the years I have bent many scaff tubes, albeit not on the Defender.
21st Mar 2019 8:43am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7687 |
Halfords ones are as good as any for casual user. Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
21st Mar 2019 8:55am |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 745 |
I can vouch for the Halfords breaker bar. Worked fine on mine.
21st Mar 2019 10:54am |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2231 |
I too can vouch for the halfords 1/2" drive. Found one at the side of the road probably 15 years ago. It's done everything I've thrown at it, including leveraging a 4ft scaffold extension. Did the axle stake nuts with it six months or so back too no problem > 110 XS Double Cab
> Instagram @simonlanemind |
21st Mar 2019 10:57am |
Thanks fellas 👍
21st Mar 2019 11:19am |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2288 |
Halfords Professional Breaker Bar 24" 1/2" Drive £28
Purchased to use in conjunction with 52mm Wheel Bearing Stake Nut Socket A 2M length on Key Clamp Scaffoldoing was used over the top of this to break them loose, at 210 Nm / 150lbf.ft...man they are tight Basic Bar on its own is a good one...seems up to the jobs asked of it... Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
2nd Apr 2019 9:56am |
