![]() | Home > Puma TDCi > Puma half shafts |
custom90steve Member Since: 21 Jan 2010 Location: South West England Posts: 16635 ![]() ![]() ![]() |
Good job. |
doublea Member Since: 12 Jul 2011 Location: Aberdeenshire Posts: 390 ![]() ![]() ![]() |
Britpart items fitted to my sister’s 90 maybe 2 months ago. Might be worth considering some corrosion protection, she’s not worried about minor cosmetics though!
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 336 ![]() ![]() ![]() |
Hmm - I painted mine in quite a few coats of satin black before fitting. No sign of corrosion. |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 252 ![]() ![]() ![]() |
Good point ! I will do something to keep the Corrosion at bay. |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 4300 ![]() ![]() ![]() |
Do Britpart do an equivalent to the 110 shafts? (LR072977 & 072976)
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 610 ![]() ![]() ![]() |
The shafts are the same on the rear. same PN for both since 2004 IIRC Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
Keith5 Member Since: 27 May 2016 Location: Scotland Posts: 217 ![]() ![]() ![]() |
Could you use Buzzweld (same as the rear crossmember kit) to protect them, and spray them before fitting? Keith |
I think I am just going to smear them with coppaslip like the road wheel flange facing.
There's always something needing done......
Dobby Member Since: 23 May 2012 Location: East Seaxe Posts: 157 ![]() |
That's just what I did this week. Found that both sides are worn, OS more than NS. Got britpart onepiece replacements as they where about £50, compared to £350 each for genuine! Looks like a case of whip out the old and slap in the new. MY15.5 RRS HSE MY13 110 MY87 90 (ex-mod) (for sale) |
The OS was more worn on mine too on the rear, seems to often be the case regardless of 1piece or two.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 9185 ![]() ![]() ![]() |
The offside shaft on a Defender will almost always wear faster and be more likely to break than the nearside due to being shorter and hence less elastic. There will be the odd exception but in general this will be the case. |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 575 ![]() ![]() ![]() |
Funny you should say that, because that's what happened to me a few weeks back. 2014 - current ..... 2003 defender td5 90 (my car)
I wonder if roundabouts maybe anything to do with it? After all there are a lot of them.
Site Copyright © 2006-2019 Futuranet Ltd & Martin Lewis
